Other 8pin ATX extension
Discussion in 'Hardware' started by gilljoy, 1 Mar 2011.
  1. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Hey all I'm just wondering if these even exist,
    My current PSU ( stupid FSP) has a incredibly short 8pin ATX 12v cable So I cant properly rout the cables behind my Motherboard and the atx wire goes right across my GPU and comes quite close to my CPU heatsink, also means I cant get a decent CPU cooler yet :(
    Any idea wither it would be cheaper to make my own, extend the actual PSU cable or just buy one from somewhere?
  2. murraynt
    murraynt Modder
    6 Jun 2009
  3. adidan
    25 Mar 2009
    This is a pack that includes an ATX extension but is the other cable in there what you're looking for? clicky
    Edit: Or maybe the one suggested by mr speedy poster there. :)
  4. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    cheers man I'll try and get one from maplins as scan charge a surchage to post to N.I unfortunatley :(
  5. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    I actually got mine in PC World :blush:
    Sleeved it all though in MDPC UV Green, looks pretty, although all you can see of it is about 5cm, the other 15cm is hidden in the cabling cavity in the case :D
  6. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Large cases often come with extension cables for the ATX power. My Cosmos S and Corsair 800D both came with them.
  7. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    i've got a xigmatek midgard, unfortunately it didnt come with one :(
    found one at chilled pc for £4 delivered, presleved too which is handy, cheers for the advice guys
  8. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    I bought 2 along with a new PSU today from OcUK: link
