Case Mod - In Progress 900 D Plexi door 6mm- (quick mod)
Discussion in 'Project Logs' started by arg-ist, 24 Jan 2016.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    My friend asked me to replace his broken 900D plexi sidewindow,but from thick plexi (6mm).
    I had a 900D sidewindow on my worktable .I studied ,and took measures of the plexi.
    Metal door has recess to fit into the slots of plexi.
    And There are also ledges at the opposite side of plexi.
    it is not possible to make these ledge , I found another solution.
    I made holes in diameters of screws at laser.and Then I enlarged them with dremel to 3mm depth of 6mm plexi .
    corners were cut of with the same diameter at laser.
    Bolts were selected a bit longer because of 6mm plexi. And they are mounted to original places.
    Plexi mounted , from inside..
    and from outside..
    packeged and shipped to my frend.
  2. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Another plexi door for Corsair 900D for m y friend vdtkc .But this time slightly different.
    we want a light strip around the plexi.
    this plexi window made from 6mm plexiglas too.
    original cover had 1.5 mm protrusion.
    for this reason it has no protrude from the metal door
    but this plexi has 3 mm protruding from the lid.
    Processed with cnc router.
    And a light strip was formed all around the plexi with this protrusion
