Cooling 92mm Rad?
Discussion in 'Hardware' started by |V| 4 L k i 3 R, 12 Jan 2003.
  1. |V| 4 L k i 3 R
    |V| 4 L k i 3 R Minimodder
    5 Jul 2002
    Ive been lookin into H20 cooling for a bit, but haven't found much luck finding one of these. I have a 92mm hole above my PSU that would be great for a rad but haven't seen any that size.
    Anyone know where to get one?
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    If there is one ive never seen it, the only ones ive seen are 120mm or 80mm....You could always get one of the 80mm ones and use an fan adaptor on it...
    [ediit]sorry, forgot the name of the 80mm one...Its the black ice micro[/edit]
  3. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    Never seen one which is 92mm, maybe you would find a one from a car (oil radiator possibly) which has similar dimensions. If that fails, I would simply expand the hole to 120mm.
  4. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    There is one for 92mm Fans, but in Germany and I don't know if the shop ships to the US. You could ask however ...
    Cooling-Solutions
    It's the W2 in Shop/Wasserkühlung/Wärmetauscher ...
    Cheers
    [DE]FreD_S
  5. Haddy
    22 Jan 2002
    Which one of those is 92mm? all look 120 to me *sept bim which is 80*
  6. olv
    olv he's so bright
    23 Sep 2002
    Yeah i couldn't spot the 92mm one :eyebrow: /me sends Fred for an eye test :p :D
  7. [DE]FreD_S
    6 Jan 2002
    As I said, it's the W2 :D
    The last bold part says it's for 92mm fans :geek: NEVER trust Google or Babelfish :nono:
    Eye test anyone ? :D
    Cheers
    [DE]FreD_S
  8. olv
    olv he's so bright
    23 Sep 2002
    lol sorry to doubt you fred :rolleyes: i must remember to have more faith :p
  9. Haddy
    22 Jan 2002
    Didnt see the W2 in ur post....Too bad its half a world away for me =/
