92mm water cooling radiator
Discussion in 'Watercooling' started by doobleshaft, 22 May 2018.
  1. doobleshaft
    doobleshaft New Member
    17 Jan 2017
    Has anyone got any suggestions on where I can find a 92mm water cooling radiator or kit? I've found it difficult to get hold of them.
    It's all I have space for on this case with rear fans being 92mm. The other computer I'm looking to setup has pipe access and 120mm rear fans so that one is easy to sort out.
  2. Big Elf
    23 Apr 2009
    Can you use a 120mm to 92mm fan adapter?
  3. doobleshaft
    17 Jan 2017
    No there isn't any space and mount holes are set for a 92mm fan. Only option I have at the mo due to the restricted space in this area of an otherwise massive case is modding the case (which I'm not keen to do) by drilling holes to get pipes.cables out and then creating an adapter plate to take custom cooling kit (I already have 120mm fans, radiators and other water cooling kit I could use).
  4. RedFlames
    23 Apr 2009
    ta-dah...
    ...whether they're any good, i couldn't say.
  5. Big Elf
    23 Apr 2009
    I looked at 92mm rads a few years ago, the biggest problem was the lack of ANY fans at that size with decent static pressure. I'm not sure whether the situation has changed in that respect but butterfly wings might be just as effective.
    I fitted the adapter to the 92mm fan holes and then put a 120mm rad on the other side.
  6. Mankz
    Mankz 5318008
    15 Jan 2006
    God that's a rip off.
  7. TheMadDutchDude
    23 Aug 2013
    That’s so expensive for a rad that no one ever uses... xD
  8. doobleshaft
    17 Jan 2017
    Not true to say no one ever uses as it is the size I need... But then it is true to say few need them as no other case I've worked on watercooling needed this size. Just found it direct on alphacool.com for 49.94 Euros or £42.85 on aquatuning.co.uk.
    So they are out there, just me entering simple search requirements clearly didn't work at the time. :wallbash:
  9. LePhuronn
    LePhuronn Member
    6 Oct 2016
    Which case?
  10. doobleshaft
    17 Jan 2017
    There's no branding on it or serial numbers.I can only state that there is no space for anything other than the 92mm fan or radiator. To use 80mm radiator I would need to create an adaptor of some kind which I could do but it will be a pain.
    The 92mm radiators do exist but looks like I can't get them at as good a price as the 120mm. When I first posted this I hadn't been able to find them.
  11. JejeLaPelle
    JejeLaPelle Member
    20 Mar 2017
  12. doobleshaft
    17 Jan 2017
    Some nice options there. I'll have a look when I take the PC apart again and make sure I have all the right parts for water cooling.
