Graphics 960 or 970
Discussion in 'Hardware' started by JitsuSparty, 2 Dec 2015.
  1. JitsuSparty
    JitsuSparty Member
    25 Apr 2011
    Good evening fine folk of Bit Tech,
    I have a significant amount of amazon vouchers to use (£120 :)) and I am planning on using this to upgrade my graphics card in my PC.
    this pc isn't my main rig - but I currently use it to go to LANs and play games on my TV... and currently has a 670 in it...
    I would like to be able to play games like Fallout 4, GTA5 MTGS 4, on it at 1080 - as such my question is:
    Would I be better off buying a 4gb 960 like the 960 Strix or a 4gb 970 like this 970 Strix
  2. johnim40
    johnim40 Well-Known Member
    23 Apr 2009
    Hi both will be fine for 1080p but if you want the extra grunt go for the 970 I play all them with a 970 and all fine
  3. TheMadDutchDude
    23 Aug 2013
    I'd go for the 970 as you've got the budget already. Always get the fastest card you can afford at the time. :)
  4. spolsh
    spolsh Active Member
    4 Feb 2012
    Against the flow here, but I'd go for a 960. It's a great card for 1080p, it's £90 or so cheaper, and by the time it needs replaced, you'll get something more powerful than a 970 for the same money as a 960 now.
    If you're thinking of going up in resolution to 1440p, then the 970 would be a benefit.
  5. rollo
    rollo Well-Known Member
    16 May 2008
    960 is already nearly at the point of been replaced. The none 4gb SKUs are already holding back newer games. ( Mordor and just cause 3 both suffer on 2gb model compared to 4gb model) the 4gb model is only about £45 less than the 970 makes it a lot less enticing purchase.
    I'd always say your looking for a 100% performance upgrade and whilst neither card will manage that the 970 is closer to the task.
    i have a couple of 680s and the 670 you have is not that much slower than one of them. And I'd not consider the 960 as a upgrade for 1 card.
    As others have said buy the best you can afford at the time.
  6. thom804
    thom804 Member
    22 Oct 2009
    Have you considered AMD's offerings? They have a bang:buck ratio at your budget that Nvidia can't really match.
    The 380X sits pretty much between the two Nvidia cards in price and performance.
  7. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    Is a 960 actually that much faster than a 670? I'd go 970 or something from AMD like a 380X.
