Graphics 9800 pro worth it?
Discussion in 'Hardware' started by chiggyman, 28 May 2004.
  1. chiggyman
    chiggyman Banned
    18 May 2004
    hey thanks guys, erm dus anybody know any good sites in the UK that do 2nd hand stuff? Because a new 9800 pro is kinda abit more expensive than i thought.
  2. Flymo
    Flymo New Member
    17 Nov 2001
    www.Lowestonweb.com has new 9800PROs for £130 delivered.
    Flymo
  3. Izdawiz
    Izdawiz New Member
    14 Apr 2003
    Is there any kind of utility to help me identify what kind of core I have in my card :confused: .
  4. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    ATItool. google it.install it then click on settings and it should tell you what core you have(unless you've flashed the bios)
  5. Highland3r
    Highland3r New Member
    25 Jul 2003
    The only utility is hands and eyes, remove the cooler and check the core.(thats to see if you have an XT core on a pro card)
    As previous post mentioned, ATI tool will tell you the current core/GPU''s bios runing
  6. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    Did you not see my post? My 9600XT is dected as a RV360 by ATi Tool even though it is running a pro BIOS!
    But yeah, in any case, you should be able to identify you're card by looking at it. Google is your friend :thumb:
  7. Izdawiz
    Izdawiz New Member
    14 Apr 2003
    So If the core is an R360 im outa luck right? Because the R350 clock better right :)
  8. daba
    daba New Member
    28 Apr 2004
    Here's my BBA 9800PRO and Nvidia GF2 MX400:
    They're both champs:
  9. toss
    toss New Member
    6 Jun 2004
    9800 pro is defiantly worth it _b
