Graphics 9800GTX+ dead?
Discussion in 'Hardware' started by jeff1155, 10 Jun 2011.
  1. jeff1155
    jeff1155 What's a Dremel?
    19 Feb 2011
    Hi there
    My first hardware failure? When I power up the screen is blank, no monitor input, and the graphics card's fan runs top speed. I removed the PCIe power connector to see if that might make a change but the symptoms are exactly the same, so it's taking all the power it needs from the slot. However, I've recently had to RMA the GTX460 that was to replace the 9800 after high load black outs etc, and I am suspicious of the PSU. Since the swap back these symptoms have occurred a few times, but now it seems permanent, so it could be coincidence that my 2 year old 9800 has chosen to pop its clogs, or a dodgy PSU all along.
    Should the 9800 be able to display something, even just boot messages or BIOS, without the 8 pin power connector, or does the blank screen prove that it's popped?
  2. Tangster
    23 May 2009
    Shouldn't it make a loud squealing noise if it's not receiving PCI-E 6/8 pin power? Most Nvidia cards do.
  3. jeff1155
    19 Feb 2011
    If it's supposed to it's not, not that you can hear much with the express train running non stop!
  4. daveh84
    daveh84 What's a Dremel?
    17 Dec 2009
    It does seem weird that you have now had problems with two different cards in the same system. Test your 9800GTX+ in a second system to see if gives you the same problem.
  5. kol
    kol What's a Dremel?
    31 May 2011
    i had this before, resetted CMOS and it worked. Dont know if this is the case though.
  6. Parge
    16 Jul 2010
    If it is broken! Into the oven!
  7. jeff1155
    19 Feb 2011
    Burn it, burn it all!
    Or does it actually fix something? :)
  8. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    dont burn it im after a 9800gtx stock cooler i would buy it from you
  9. jeff1155
    19 Feb 2011
    Bizarrely, it's working fine now, but following the 4870 upgrade thread and just in case the GTX460 RMA doesn't work out, I've just ordered a Sapphire 5850 from ocuk, £99.98 was just too good to miss!
  10. mrbungle
    20 Sep 2004
    lol what did you do to the one on the card originally.
  11. penryn 2 hertz
    10 Jun 2010
    well i had it on a chair while i was putting the thermaright cooler on and well let's say ass vs stock cooler's dont mix too well you get the jist...
  12. mrbungle
    20 Sep 2004
    Oh dear :(
  13. penryn 2 hertz
    10 Jun 2010
    not to worrie im running a gtx 460 1gb now tho my athlon dual core 250 3.0ghz is a far bottleneck im looking for stock cooler so i could use it as physx card but i dont think the power drain is werth it my fraind is after the card but i neeed to find a stock cooler iv got my eye on a 9600gso for physx less power and a much smaller card...
