right. ive found a 9800pro on micro-direct for £130 (ish) but i need help. there are some 9800s out there with hydrix mem that can be flashed to an XT, can anyone tell me if the card ive found on micro-direct IS that card? http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=5915&GroupID=330
no need for the help. got some bods on MSN to help. BIG thanks to anyone who was thinking of helping. thanks again
LowestOnWeb have the 9800Pro for £125 delivered (IIRC). Whether or not a 9800Pro will flash to a 9800XT is more dependent on the core it uses, R360 vs R350. Even so it makes almost no difference as the XT is only a touch faster and most Pro will clock to or past the XT. The XT is really just a Pro with slightly higher clocks.
