Graphics 9800pro / Radeon 7000 problem
Discussion in 'Hardware' started by Sc0rian, 16 May 2006.
  1. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    ok i got this really annoying problem that is driving me up the wall.
    I have 3 monitors, 2 on the 9800pro, one on the Radeon 7000 pci card.. but the monitor that is on the pci card always sticks at a low hzs.. i can change it but what ever option i do to tell it to remember it keeps going back to 60hz's.. its bloody annoying.. any ideas?
  2. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    Hmmm... not come across that before....
    Would usually suggest checking the driver display settings, but I guess your ATI control panel will only relate to the 9800....?
    Something like Powerstrip might be worth a look- I'm sure you'll be able to setup profiles for each display......?
