Graphics 9800pro to 9800XT BIOS flash guide
Discussion in 'Hardware' started by unclean, 24 Jun 2004.
  1. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    i've just read Rojaks pot guide on XT to pro but i'm still non the wiser on how to see if i've got an XT PCB.
  2. unclean
    unclean SMP obsessive
    30 Dec 2003
    google image search...
  3. Piratetaco
    15 Apr 2004
    do you mean the core(defo an R360,the ram samsung part number K40263238E-GC2A. batch number 404 the magical sapphire one.)or the actual PCB with all the little resistors on?
  4. unclean
    30 Dec 2003
    How do you mean what do i mean?
    The flash should work on all R360 cores, regardless of PCB.
  5. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    Doesn't this card run hotter when flashed to 9800XT?
  6. Piratetaco
    15 Apr 2004
    my PCB is missing FM63 thus its an pro PCB.once i get a working floppy drive i'm going to try my luck with the flash.
  7. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    If you still need the pic:
    Cheers,
    Mike
  8. unclean
    30 Dec 2003
    Yes, as i said.
    Could people read the post before asking questions :grr:
  9. Piratetaco
    15 Apr 2004
    the thing i was looking for was on the other side.its chip number FM63 and its what monitors the temp of the core.but my pro doesn't have it :waah:
  10. Dinh
    27 Jun 2004
    Well, Sorry man, im a 56ker... page load half way and for some reason.. stoped.
  11. unclean
    30 Dec 2003
    1337modderman.. there is an obvious difference in the PCBs.
    The temp monitor is only on the 256mb XT, and the 256mb pro which has the R360 core, and is on the XT PCB, as it is EXACTLY the same card as the 256mb XT. You can only unlock the temp monitor on the 9800pro w/256mb.
  12. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Anyone know what core the Sapphire 9800Pro cards have ?
  13. Piratetaco
    15 Apr 2004
    you're going to have to take the cooler off to find out what cooler you have.its burnt into the Die under the cooler.
  14. unclean
    30 Dec 2003
    Please, :read:
  15. nosmo
    5 Oct 2003
    But I havent bought the card yet.
    Was asking so I can be sure it will be moddable.
  16. unclean
    30 Dec 2003
    Nevermind, i just thought from what people had said in this thread it was kinda obvious what cores the Sapphire 9800pros had..
    But i suppose no one directly said "Sapphire 9800pros currently are shipping with the R360 core".
  17. SFOD-D LoneWolf
    10 Apr 2004
    Check the pics I posted above, there of a Sapphire ATi Radeon 9800PRO 128MB that I bought a few days ago.
    Cheers,
    Mike
    P.S.
    You can clearly see the R360 core :rock:
  18. SFOD-D LoneWolf
    10 Apr 2004
    Urgent Question!!
    Does the OverDrive and temp meter still function after flashing to a XT??
    Cheers,
    Mike
  19. unclean
    30 Dec 2003
    No, unless you have a 256mb version, which is, as i said, indentical to the XT.
  20. SFOD-D LoneWolf
    10 Apr 2004
    Nevermind....I just sold my 9800PRO@XT and I'll order a X800 within the next few days.
    Cheers,
    Mike
