____ HTPC, Update 3, 9/9/07, page 2
Discussion in 'Project Logs' started by arkadur, 20 May 2007.
  1. arkadur
    arkadur New Member
    3 May 2005
    hey all :naughty:
    i started a new project, but , as you can see, the project is nameless
    because i didnt decided yet it is the best to
    the major target is a small case, so i am using MINI ITX mobo.
    some sketch of the case:
    Front
    Top
    close up on the ring:
    Side
    ISO
    and inside..
    Back
    after some shopping:
    nickel led holders:
    and some switch
    and the third hand device
    in the last week, i had ordered the materials for the project (like alu profiles, perspex strips, perspex cubes, leds, and special ring that create on a lathe
    the rings:
    the big one
    middle
    together
    and the small rings (for the switch on the front panel)
    The perspex staff:
    the strip for the sides of the case:
    and the perspex roll, (i'll make a spacers from this)
    perspex cubes
    i had create 2 types of cubes
    1. 20X20X20 (visible)
    2.16X16X20 (hidden, it's will be inside the Alu profile)
    the visible cube
    and the hidden cube
    the result that i want to get is like this:
    the Alu profiles:
    and with the perspex strips
    and for the end, some leds that be placed in the hidden perspex cubes
    that's it for today guys.. :hip:
  2. DimaX
    DimaX New Member
    7 May 2005
    Looks sw33t!
    Good Luck!
  3. dragon2309
    dragon2309 techie
    28 Jul 2006
    looks like it could turn out to be a really nice HTPC, one thing, your intial drawings for this state the height to be 80cm.... im really hoping thats a typo and its 80mm, but then i look and all of your other measurements are in cm aswell.... the length for example is 240cm... thats longer than me..??!!?!!??!
    dragon2309
  4. arkadur
    arkadur New Member
    3 May 2005
    oh..
    that a little mistake in the sketchup6 setting..
    sorry for fooling you with wrong units and sizesin the sketchup sketches :blush:
  5. Dj Ovin
    Dj Ovin New Member
    7 Nov 2005
    looks very nice this one! cant wait untill you start on it :)
  6. wbdog206
    wbdog206 not me
    15 Jan 2007
    looks interesting,i'll keep an eye on this one.
  7. THRASHER2
    THRASHER2 Pimpin' Deals 24/7
    15 May 2007
    Bling! Bling! :rock: MOD ON!
  8. Bas van der Werff
    Bas van der Werff New Member
    18 Feb 2007
    nice design :thumb:
  9. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I like the design. Nice sketchup work, looks like you've planned it well and everything will fit nicely. I'm following this one :thumb:
  10. Guest-16
    Guest-16 Guest
    Make sure you know where the fans for the PSU are, what kind of cooling the hard drive will have and what cooler you are putting on the CPU.
    Just a warning from someone who's done a custom SFF before :)
  11. Neji
    Neji New Member
    3 Jan 2006
    I love the design but I'm not too hot on the colour scheme. I kind of like the colour in your sketchup and the yellow is great but I'm not sure about the blue. Oh well I'm sure you'll make it look great. :)
  12. Xlixen
    Xlixen New Member
    16 Apr 2007
    Wow, I'm gonna watch this one. Good work :D
  13. arkadur
    arkadur New Member
    3 May 2005
    Thank's for the commets guys.. :)
    #bindibadgi : the PSU fan is on the rear panel of the case
    about the HDD, i dont know yet, maybe it's will be a fan on the top of the case, some kind of HDD coller ( i hope the 80 MM intake fan on the front panel will be enough)
    in theoretical method, i didnt to be worry about heat in this case
    the core heat output is just 2.5W (40MM fan - stock, and i bought Zalman sink to make it more quiet .
    I'll upload some pics of the MB in the next update.
    #neji : the theme of the case include ALU in natural color, and yellow perspex,
    please, dont relate to the color on the sketch .
  14. arkadur
    arkadur New Member
    3 May 2005
    UPDATE 2
    hey all :)
    Update 2:
    I made 4 of 8 pexpex cube connector, for the Alu profiles..
    some Pic's of the result:
    and the last one:
    the perspex with the 10MM led :naughty:
    i hope that i'll have a bigger update in few day's..
    have a nice day..
  15. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looking good!!
  16. DeKemp
    DeKemp BEER.
    21 Feb 2007
    The blue cubes are just breathtaking :thumb: :thumb: :thumb:
  17. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Niiiiice... You got me subscribed :thumb:
  18. Dead Ghost
    Dead Ghost New Member
    11 May 2007
    Very, very nice design.
    Why don't you use a PicoPSU 120W? It will save you a LOT of space. Also, you could use a laptop dvd drive, saves some space too.
  19. widmod
    widmod Member
    9 Oct 2006
    nice idea for the case conectors
    and also a nice design overall
  20. DAE_JA_VOO
    DAE_JA_VOO New Member
    11 Nov 2005
    How did you make those connectors?
