Case Mod - In Progress ______RESURREKTION______
Discussion in 'Project Logs' started by mnpctech, 22 Apr 2011.
  1. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    lol probably why I like it
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    @Nutman, haha! use them for mounting I&H reservoirs on each side :thumb:
    @Waynio, probably not...hehe, but does look cool :D
    @nagyizom, Thank you! and I agree, this will be better!
    @Dragonite, very true, I will take lots of photos for you :thumb:
    @Blarte, I love destroying and rebuilding things...lol
  3. mnpctech
    21 Apr 2003
    Removing the TUF shield (The Ultimate Force) on the Asus Sabertooth P67 motherboard. It's fastened on with 8 screws on the back.
    You can install an optional "assistant" 50mm cooling fan that screws into the portal pictured above. The assistant fan is an optional component and doesn't come with the Sabertooth.
    Asus recommends mounting a CPU cooler that will blow airflow downward, toward the CPU socket.
    Using Heat gun to remove the sticker
    Using red Scotch brite pad to scuff surface of the TUF shield
    Applying Flat Black "Flexible" Primer for adhesion coat on plastic, before applying Matte Black Enamel Paint
  4. bulldogjeff
    2 Mar 2010
    I actually forgot about this one. I love the warning sticker, it's amazing how direct translations loose their way some times..lol And the Saber tooth whens it's stripped sown looks very ordinary all of a sudden. I'll be watching to see how that spray job comes out. I'm getting Ideas now. I never realized that the mobo was vented either, I'm thinking a couple of well placed LEDs.....mmmmmm
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    That cover would look even better camo and a pair of Corsair Vengeance stick would not look out of place either on that board
  6. Guest-56605
    Guest-56605 Guest
    Your board finally turned up then Bill :thumb:
    Its one sexy bit of kit!!! :naughty:
    Not that I'm biased of course ;) :D
  7. Karrek
    Karrek Minimodder
    7 Jun 2011
    I like the picture of the "do not remove" sticker; with the next picture showing the screwdriver proceeding with the action.
    I also noticed, and liked, the addition of the Lego. You made it all fit so well - looking good!
  8. Kovoet
    26 Aug 2009
    Not a bad board my friend almost as good as the ASUS GEne range :D
  9. Cheapskate
    13 May 2007
    Do you have enough room for that mock CF film?
  10. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    Loving this....sub'd
  11. mnpctech
    21 Apr 2003
    @bulldogjeff, the p67 covers open a new realm to modding
    @23RO_UK, yes, and please contact me when your Noire build is finished bro!
    @Kovoet, you hit the nail on upcoming project this fall, ie: digi camo theme inside/out :lol:
    @Karrek, much easier to get lego instead of sourcing collector sci-fi model kits off Ebay :thumb:
    @cheaps, strictly matte black finish for this one, with exception of painted highlights
    @Nanosec, thanks bro!
    I wanted this build to be the 1st with "hand painted" artwork on the TUF shield, that reflects the theme I created on the chassis. So I enlisted Brad's paint skills. In return, he asked that I take him out to dinner at Big Bowl with Knob Creek and Cokes :cooldude: which is fine dining to us backwoods hicks. So, the cover for optional 50mm fan served as nice location for bio-mech skull taken from the front of the chassis. Brad chalked out general idea and location for the artwork. Other than using hand made square ribbon stencil and corsair 600T intake grill as a stencil, everything was painted off the cuff, freehand without stencils. Since ASUS was kind enuf to send me the p67, it's only proper that their logo gets incorporated into the artwork. (since I removed their stickers!) I'm also leaning toward anodizing their Green heatsinks Black...btw" Notice how the mb heatsink matches the Green paper on the table perfectly? coincidence or a warning to not change them?.... btw: You won't see the brown & tan gpu slots
    Don't pay $40 for professional airbrush stencils! Make your own, grab image online, edit in photochop, print it, then cut it yourself with Xacto knife.
    I just happen to have an intake grill from corsair 600T in my car...lol. It served as perfect stencil for airbrushing the mesh grid background. Otherwise Round Modders Mesh would have worked too!
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Shiiiiiiiiiiiiiiiiiiiiiiiit!
  13. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Ok, that's definitely worth retweeting ;)
  14. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Awesome airbrush as ususal. :thumb:
  15. kier
    kier -----------------
    1 Mar 2011
    This makes me wanna airbrush too, gonna give it a shot
    Really great, respect Bill and offcourse Brad
  16. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    so glad to see this is still alive, gets a little excited again. nice paintwork there sir.
  17. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    wow... very nice airbrush :)
  18. Guest-56605
    Guest-56605 Guest
    Will do Bill, should be all sorted in the next couple of weeks :)
    QUALITYYYYY!!! What more can I say, I'm a huge fan of airbrushed art and that is just right up there! :thumb:
  19. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Nice paintwork, you wouldn't be a Mr H.R. Giger is disguise?
  20. mnpctech
    21 Apr 2003
    @Nutman, you swore! :nono: :D
    @brinkz0r, haha, sweeet!
    @Blooddrunken, Brads da man!
    @kier, I have no doubt you would be good too :thumb:
    @Stem83, me too, was a treat to blow dust off this project for this weekend,
    @ColdzeroTeam, "off the cuff" art is the best imho
    @23RO_UK, sweet, look forward to the final piece :rock:
    @AJB2K3, Brad did the paint on the mb, him and I are huge fans of GIGER
