Scratch Build – In Progress ___The "MOD MEN" PC___is FINISHED!!!
Discussion in 'Project Logs' started by mnpctech, 3 Feb 2011.
  1. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    not sure when he put it up but it was there on the window when i went by the other week. i just nodded politely and didn't question it.
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Why wouldn't anyone question a PC hanging on a window? ;)
    On a more serious note: great video, guys. Also nice to see the real face behind the monkey mask. Actually, nothing like I had imagined Cheapskate to look like IRL (not that I spent much time imagining what the real Cheaps might look like).
    Will the motherboard just hang there in the open, or will it be covered somehow?
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    @DeadP1xels, pack your suitcase, it gets even worse...well, ridiculous would be better description ..lol
    @k.3nny, during box opening quick tip, you can see it's clear acrylic cover leaning on the wall... it comes off for special occasions :D
    @nutman, cheaps is devising a cool solution for that!
    @Dragonite, The DELL was stuck on the shop window in September and still there. It's grown into something bigger....:worried:
  4. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Great video. Now at least I understand what the deal is with the countersunk screw pic.
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    GOD... MY EYES! Put the mask back on Cheaps! :p
    Nah, looks cool, and I really like the video! :thumb:
    But yeah, what a tease... I wanna see some milling-action! I usually only work in the smaller department of the acryllic sizes! :)
  6. Cheapskate
    13 May 2007
    You should do a segment on how to remove Dells from window glass now. At least do a segment on removing tape residue.
    Be careful. It might involve breaking the window.
    ...And you didn't answer my last question. That means the material died and became a mountain of plastic fluff. :waah: Should be spectacular to watch at least...
  7. Combatus
    16 Feb 2009
    Looking lurrrrrrvly Bill! It's going to be a stonker of a project!
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Watched the first episode & liked it :D I had a good giggle at the window mod :lol::rock::thumb:.
    So glad there is a pc modding show now :thumb:.
  9. Cheapskate
    13 May 2007
    Back to my mistake diary.
    This was my setup for the first attempt to tap the waterblock top. I have a case of sockets that are all the same height across the top row. I've used them in the past to hold the work level in the vise. I did not realize I had the wrong set here, and didn't bother to check...
    I noticed while tapping the first hole, though! This one went in the reject pile. The second top I made crashed during the cut, and I lost the zero point.
    Both parts were salvageable, because I needed to make some spacer plates for the motherboard cover.
    More screw-ups as I remember them...
  10. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Ah Niice, Table is soo awesome :D! i watchd the build of it.
    @cheaps, Bleu top looks goood :D! although its a failure top :blush:
    Keep on going Mod Men!
  11. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    Well, I'll be keeping an eye on this one. Awesome design but the casts definitely add a lot.
    I almost feel cheated by the Cheapskate revelation though. Shouldn't he look more ape like or ludicrously awesome? :confused:
  12. Warsmith
    Warsmith Enginseer
    5 Dec 2010
    That's just Cheap's mild-mannered disguise. He really is the monkey...I promise!;)
  13. Cheapskate
    13 May 2007
    @Grimloon - Are you implying I'm not ludicrously awesome looking?:eyebrow:
  14. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    ^^ You're begging to get hurt!
  15. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    QFT :thumb:
  16. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Awesome block! :jawdrop:
    Congratulations! :thumb:
  17. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    it was really cool to see cheaps' face
    and i love the first eppy!!!!!
    i want MOAR!!!!
    you should put links to all of the awesome tools you use
    like that krazy tape
  18. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    When you're tapping acrylic, you should try to not hold it by the sides. It bends no matter how little pressure you apply to it. Try to clamp it from the top as well so it stays flat. I noticed that those barbs are coming out crooked.
  19. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    do you really think so?
    I am pretty sure that's the reason he posted the pic, to show us what he messed up. The guy is phenomenal at scratch builds, he wouldn't let something like that slide on his own case, let alone on something being used for someone elses project.
  20. Nutman
    21 Oct 2008
    Well, guys. I'm sure that Cheaps just wanted to show some of his mistakes. Adds a bit of fun to a build - also encourages others to have a go at it, saying that even the good ones do fail, so don't you worry about failing.
    Still, nice advice from Achron there.
    EDIT: Hey, Cheaps - why don't you just bolt the top to a flat piece of wood, instead of clamping it on the sides?
