That looks great. I think you should buff the logo, not paint it. The contrast would be evident, but very subtle. EDIT: On the other hand, I can totally see how blue would work too. Moar options, I guess
I Really like the subtle contrast on the side panel right now. You're sure you can't/ don't want to leave the Raised portion Bare aluminum and put a piece of blue acrylic behind the FUZION cutout?
hmmmm, I can always experiment with different ideas too. and Thank you for the comments and feedback guys
Thank you Ron! While deliberating about the side panels, I've re-installed Adamas factory PWR & RESET switches and NZXT's stealth Optical drive cover, also painted with the chassis. The "Fuzion" portion of the front logo will have Transparent Blue Acrylic behind it. Re-installed the painted 5.25 bay sides
wow looks damn good , though i wouldn't use transparent blue plexi, but more a nonsee through 1, and put some white leds of the side of it or so,
Glad ya'll like it! (scratches chin) hmmmmm.... Today I'm running on auto pilot and figured I'd do some low-impact modding. I'll just replace the factory feet on Adamas with our machined aluminum "diamond Knurl" case feet. These are cnc machined from 3/4" diameter 6061 aluminum. Base Diameter = 1- 3/4", Height = 1"
I always think that silver/metal and blue feels cold, you going for a looks cold must run cold approach lol. Serious note.... your diamond knurled feet work perfect with this case!
