Case Mod - In Progress A Begginers Mod "The Noob" +two way mirror to the dvd/cd drive
Discussion in 'Project Logs' started by WolfandAngel, 7 Apr 2009.
  1. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    Hello this is my first Casemod and I did it because I wanted to Watercool my Pc
    the Mod name is temporary if anyone hase a better name please say so
    Finished this is after the remodling
    I don't know the name of the Case so if anybody knows please tell me ?:sigh:
    I dont have many pictures of the first part of the Mod :waah:
    holes for the cables
    The PSU and Harddrives are going to go in the basement
    Starting the Watercooling
    Cabels for the Fans
    Some tubing
    Some Art
    Waterproofing the mod
    I used toilet paper to see if any water would be leaking
    This is the first part of the mod im going to uplode more picture of me Remodling the Case this week:rock:
    :confused:I'd like your feed back on the first part of the Mod ore suggestion how to make the writhen part of the thread better like should i expain more what i did
  2. WolfandAngel
    2 Dec 2008
    part 2 Remodeling:dremel
    part 2 Remodeling:dremel:
    After 4 months i decidet to do a few changes on my case
    taking every thing out tok me 10hours:jawdrop:
    cutting in some thread into the radiator because befor that i forced the screw
    + got a Rad grill:D
    my new work space
    we got circular saw but it semmed to destroy the acryl glass
    so i used my smaller version off circular saw
    Finishing the side window
    some new hardware
    making a hhd Rack
    i wanted the motherboard to have a red orange glow bot it dident loke like i expected
    a real mess
    here you can see the backlighting of the led i put in maybe its to bright to see it with red fans
    uv reactive tubing and so on
    more new hardware a Zotac GeForce GTX 260 AMP²! and a 8400 whitch is going to run in physx
    finished :clap::clap:
  3. Mr. Beta
    Mr. Beta What's a Dremel?
    27 Feb 2004
    That's pretty neat. I like the way it all looks and that little "basement" you added to the case.
    What kind of table saw is that. It's tiny!
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
  5. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    congratulations with your first mod :)
    A little suggestion though: paint the wooden frame black to match the case :)
    Nice mod for a first time dude :thumb:
  6. popotheflyingpanda
    popotheflyingpanda What IS a Dremel?
    20 Nov 2008
    This looks great! Like the window and the tubing.
    Also are you going to w/c the gfx? seems like it would be the next step if you wanted.
    Also a little suggestion for the basement, as said paint it, but also see if you could extend to further to match the front of your bezel, it looks like the case is hanging over a little.
    Anyway, Looks great! would love to see more, and nice set up!
  7. WolfandAngel
    2 Dec 2008
    Mr. Beta : Bench Circular Saw KS 115 got it because its so small but cutting stuff
    that longer than 30 cm is a pain:wallbash:
    jegerjon : Not sure if I will paint it don't want to take every thing out again
    maybe I'm going to make the main window into a two way mirror:D
  8. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I like this picture a lot
  9. Huca
    Huca What's a Dremel?
    15 Oct 2006
    agree with modsquad!
  10. WolfandAngel
    2 Dec 2008
    First thx for viewing this mod
    some updates I added new screws to the front fan because I didn't like the original ons
    and I though they looked good on my other mod [​IMG]
    and I added a two way mirror to the dvd/cd drive
  11. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    I'd cut that out all the way and add a proper fan cover.
  12. WolfandAngel
    2 Dec 2008
    popotheflyingpanda not going to and I don't have the money :sigh:
    planing a new mod for the summer Project"Key Hole" :D:D
    not even finished and planning a third
  13. Nooby4Ever
    Nooby4Ever 2 left hands
    19 Jul 2008
    Nice mod but your cabels are very messy , you should clean them a bit
