Cooling A bit of a David & Goliath
Discussion in 'Hardware' started by coolmiester, 14 Apr 2004.
  1. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    /.........well you know what i mean :D
    Just had the chance to run the new Danger Den Laing Pump up against the Eheim monster 1260 and it didn't do to bad.
    OK, a simple test to see how long it takes each pump to fill a 5lt container.
    Looking at the 2 pumps side by side you would think the Laing wouldn't have a chance but its got to be said this pumps got attitude and puts up one hell of a fight.
    Eheim 1260 = 20 seconds
    DD Laing = 23 seconds
    pic of the Laing squaring up to the Eheim 1260
    I know you will probably think i am biased on this which i am to a degree but i would never recommend something i would not feel comfortable using myself so here is my honest opinion on the noise issue.
    When i first powered the Laing up i thought well its not to bad, (more of a high pitched humm) then once the water had filtered through it got more and more quiet and once i had stood it on the dense foam base pad it comes with it became well within what i would say is acceptable and would have no problem running these in any of my machines.
    The power and size of these tiny things is awesome.......plus they are 12volt which will appeal to a lot of people :thumb:
    here's what it looks like alongside an Eheim 1250
  2. slater
    slater Mummy Says Im Special
    18 Apr 2003
    That thing would woop a 1260 once you put the heat issue in the equation. :thumb:
    (i need 2 of these but dont have £100 to spare!)
    Have you got any info on running them higher than 12v? are thay not rated for 24v or something. I would luv to have one (or 2 :hip: ) on a rheo!
  3. pauldenton
    pauldenton What's a Dremel?
    8 Feb 2004
    is that the 3/4" barbed version? - and if so is that what you stock?
  4. coolmiester
    31 Dec 2002
    It says 1/2" Noryl Hose Barbs on the box!
    As you can see from the first pic the Danger Den hose just pushes straight on to a nice snug fit..........probably get away with out hose clamps TBH but i'm not a big fan of that i must admit.
    I haven't really had time to try the voltage out..........i just hooked it up to a 12v PSU but no doubt i will be experimenting at some point as i think they go down to 6v also.
    Amazing little things they are!
  5. pauldenton
    8 Feb 2004
    just looked bigger than the eheim's barbs... must be the camera angle (or my eyes..) they look nice smooth barbs to put a clamp on...
    i must admit i'd be sorely tempted, if i hadn't just got something (or should that be things) altogether more excessive... ;)
  6. JRY
    JRY What's a Dremel?
    28 Feb 2004
    i just ordered one of those dangerden pumps!! WOOHOO!!!
    pics are acoming!! :p
  7. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    Can you test the head on both pumps, or would it be too high to test yourself?
  8. coolmiester
    31 Dec 2002
    yeah i'll try but it might have to go on hold till the w/end though
    ......i'll see how i get on!
    [edit]............me wants to know what Mr Denton has in the way of excessive......sounds very interesting :naughty: [/edit]
  9. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    That looks damn cool, so if it beats the 1260 lol at the 1250 hehe :). Tiny thing too by the looks of it.
    Very nice :)
    morgan.
  10. Bugaloo
    Bugaloo What's a Dremel?
    27 Sep 2003
    Ocshoot.no is doing a overkill project, using a oceanrunner 6500. It`s compared to a couple of eheims on this thread on ocshoot.no`s forum.
  11. dom_
    dom_ --->
    4 Jan 2004
    OH MY GOD!
    http://home.c2i.net/w-201899/6500.jpg
    why is he using this!
    just quickly coolermiester, what is the retail on this little pumps?
    <bigZ>don't steal other peoples bandwidth :grr:</bigZ>
  12. Bugaloo
    27 Sep 2003
  13. Remote Man
    Remote Man What's a Dremel?
    17 Sep 2003
    ocau forums has heaps of info on this little pump.
    Cathar has spent ages playing with it.
    at 7v it's near silent and 16v makes it loud.
