Build Advice A bit of advice please
Discussion in 'Hardware' started by THP Dan, 12 Jan 2011.
  1. THP Dan
    THP Dan What's a Dremel?
    21 Jul 2009
    Budget: Around £1500 - can make it more if its needed
    Main uses of intended build: Gaming. a bit of Photoshop and cad (not too important)
    Parts required: Whole system - I have a case: Coolermaster CM 690 II Advanced (will be modding so no space problems)
    Previous build information (list details of parts): N/A - nothing that can be salvaged
    Monitor resolution: 1920 x 1080 (2 x 24")
    Storage requirements: 1TB is fine
    Will you be overclocking: yes i probly will
    So far i have in mind:
    CPU: i7 2600k
    GPU: I was thinking a ATI 6950 (not shure on this)
    Mobo: Asus P8P67 Pro
    Memory: 8GB (2x4GB) Corsair Vengeance
    PSU: Corsair Pro Gold AX850 (i know its overkill but i need that for lighting :rock:)
    Storage: 1TB Samsung Spinpoint F3
    SSD: 64GB Crucial C300 (just for os and a few programs)
    CPU Cooler: ThermalTake Frio
    OS: Windows 7 Home Premium 64bit
    DVD Drive: i have one, would love a bluray slotload if you can get one?
    Total is £1,167
    Thanks
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Drop the CPU down to a 2500K. You will not notice the difference to the 2600K but your wallet will.
    What do you mean by "lighting"? Even a 500w PSU will be more than enough for the rig, an 850w is waaaay overkill.
  3. THP Dan
    21 Jul 2009
    Will do thanks,
    I might add another GPU later on.
    There could be 100-200w of LED's running off it (got a big plan)
  4. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Some of that rig is a tad OTT. You don't need the hyperthreadinh or premium PSU.
  5. THP Dan
    21 Jul 2009
    I think ill still stick with it just incase i decide to add more ;) always good to have the room to improve.
    Will a 6950 be alright running my monitors?
  6. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    100-200W for LEDs?!?!?!
    What are you planning that involves 1500-3000 LEDs? Or have I missed something?
  7. THP Dan
    21 Jul 2009
    RGB ;)
    100-200w is the very max it will be (thats all my custom built controller can take)
    plus i might be adding some external LED's, who knows ;)
