Modding A Call to All Modders/ Designers
Discussion in 'Modding' started by Static Lullaby, 1 Feb 2006.
  1. allforcarrie
    allforcarrie Banned
    22 Jul 2005
    :eeek: :eeek: :eeek: :eeek: :eeek: :eeek: Static Lullaby
  2. Static Lullaby
    Static Lullaby What's a Dremel?
    1 Feb 2006
    Yes?
  3. ajampaniki
    ajampaniki What's a Dremel?
    14 May 2003
    Well it didnt turn out like I wanted, but here goes.
    I always see mods on the internet where ppl build an expansion for theyre case to fit theyre watercooling, or build external casing for it. This is where my idea started.
    My idea is to start of with a simpel basic case that has room for the basic components of a computer. It could also house a watercooling setup, but that would be kinda cramped. The standard case has room for 6 dvd drives or a removable hd rack.
    The case consists of a frame with aluminium plating on it.The front is a sandwich of aluminum and a material of choice (plexiglas, mesh..) The little cover can have several functions. It could be a baybus, lcd cover, reservoir, almost anythyou could think of.
    The motherboard tray is removable and can be reversed for atx and btx positioning
    To make more room for watercooling or extra drive space, one could buy an upgrade for the standard case. This consists of a smaller version of the case or one of the same size. There are endless combinations and the case can become as big as you want to. The seperate cases are connected with thumbscrews and cover plates on the front.
    The basic case with smal extension is big enough for a 2x120mm radiator or 2 120mm radiators, 2 pumps and 2 radiators for seperate loops for gpu and cpu.
    With all of this I wanted buyers to be able to create theyre own unique case with all the things in it they want, without having to construct a seperate casing that looks nothing like theyre own case.
    I might enter with another case to if i have time left.
  4. Static Lullaby
    1 Feb 2006
    Thanks for the submission! Looks great, I hope you get a chance to put another one in as well. Best of luck
  5. Static Lullaby
    1 Feb 2006
    New deadline Just announced!!
    Just announced...there is a new deadline for entry submittal. The new deadline is Feb. 25th. All submissions must be made by 5pm Central Standard Time. A poll will be posted in each of the participating forums on the 26th witht he top 10 submitted designs for the users to vote on their favorite picks.
    The decision to move the initial deadline back is based on a number of participants with nearly finished work done on their design needed a little more time.
    Best of luck to all!
  6. freemc
    freemc What's a Dremel?
    20 Feb 2006
    *few* that's a relief. I was kinda planning to work through the night. I guess with three extra days I won't have to and I could make a more detailed design.
  7. Static Lullaby
    1 Feb 2006
    Glad we can be of assistance! Best of luck in the contest and welcome to Bit-tech.net
  8. xrain
    xrain Minimodder
    26 Jan 2004
    THANK YOU STATIC im saved :D
  9. Static Lullaby
    1 Feb 2006
    Not a problem. You can thank my partners and the many folks that wrote in letting us know they would not be able to submit entries byt he due date LOL... Best of luck to all. I hope to see some more solid entries over this extension period here.
  10. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Ive actually been toying with an absolutely GIGANTIC case design of my own for awhile, going so far as to detail all the metal folds, screw holes, etc, long before I learned of this contest; I think Ill put it up as it is, so you can all see it; internally, its basically complete, I just need to finish the exterior :)
  11. Static Lullaby
    1 Feb 2006
    GIGANTIC??? Hmmmm let's see it!
    Best of luck to you!
  12. Nix
    Nix What's a Dremel?
    22 Nov 2005
    *thinks of the jolly green giant*
    Note i will laugh it is indeed green just for ironies sake :D
  13. Static Lullaby
    1 Feb 2006
    lol, now that would be interesting.
  14. Nix
    22 Nov 2005
    Seeing someone had to do fancy renders *glares at a certain someone* i decided to upgrade from the craptastic sketchup renders to some 3dsmax renders.
    Hope you like.
    All comments and critiques are welcome. Should have the night time renders with all the led wonderfulness if i can get it to render correctly.
    Plus another design for submission.
    Anyway time for sleep :D
  15. Static Lullaby
    1 Feb 2006
    Absolutely awesome work! Definately a difference from the original sketchup design.
  16. Nix
    22 Nov 2005
    Just note that the case will have feet that i will do later tonight so the case wont be flush with the floor, it will be raised for air to be sucked up through.
  17. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    OMG!! 25 februari ...thats realy soon...why do I always find these things to late. Well, guess I have to take a day of and make some speedy 3D moddeling. :wallbash:
  18. Static Lullaby
    1 Feb 2006
    lol this has been up here for three weeks now. Not sure why anyone hasn't seen it yet? Best of luck to you getting things in order and a design in.
  19. Static Lullaby
    1 Feb 2006
    Deadline is creeping up on us soon! Two more days left, so get those last minute entries rolling! Good luck to all!
  20. Nix
    22 Nov 2005
    And heres my second piece.
    Drummed it up in an hour so i know theres some probs with it... such as the curve of the window not being the same curve as the panel.
    And also the fact it looks like a chocolate orange at the moment.
    But its just a little pic for you guys to have a look.
    Case Specifications:
    MATX Mobo
    ATX Psu
    Dual 120mm rad intake (front)
    dual 80mm exhaust (back)
    1 cd drive
    Will have a fan controller and a lcd matrix besides and underneath the cd drive.
    Hdds.. well it can have roughly 8 if you have no pump but i would say about 4 if you do have a pump.
    Will try and work on it tonight but will be out most of the night for a nice long well earned drink :D
    Feedback is always lovely, but do make it constructive.
