Modding A Call to All Modders/ Designers
Discussion in 'Modding' started by Static Lullaby, 1 Feb 2006.
  1. Static Lullaby
    Static Lullaby What's a Dremel?
    1 Feb 2006
    You would be amazed @ what we can have produced:D. Just about anything that can be dreamed up can be put into production.
  2. ajampaniki
    ajampaniki What's a Dremel?
    14 May 2003
    Do you maybe have the font for the logo you made? Would be usefull for my 3d program
  3. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    Some explanation...
    The main pod is fiberglass with an aluminum base that all of the components mount to. The entire main pod lifts off of the base to service the innards.
    The bubble top is smaller than the one used on Badassumption and rather than being powered to lift, like on its predessesor, it using a hydraulic cylinder similar to (but smaller than) what you find on a hatchback. The dome ring is 3/16" thick aluminum.
    The BaDactivity pod in front has the power button in the center and chasing LED's (genius of BitTech member extraordinaire, Starbuck3773T) that monitor HDD activity around the power button. This is a direct copy of the similar pod used in BaDassumption.
    The two tubes behind the BaDactivity pod are aluminum tube air inlets for the power supply.
    The reservoir is a modified standard reservoir (modified with an orange transparent bubble top).
    The optical pod is identical to the one I'm now building for BaDassumption and uses a SATA DVD burner. Its made of polished billet aluminum.
    The inline coolers coming off of the radiator are similar to the ones used as bulkhead fittings in BaDassumption. The radiator is a Chrome Xtreme and is fit with a shrouded 120mm fan behind it.
    Is it a buildable design? You betcha. It would be a slam dunk compared with its "father".
    I want to give Jazzle's SketchUp models a shout out... they were extremely helpful.
  4. Static Lullaby
    1 Feb 2006
    The font is called "Refluxed" you should be able to find it for free online. If not feel free to e-mail me and I can reply with it there. Thanks!
  5. Static Lullaby
    1 Feb 2006
    Thank you for the other submission! That is definately an interesting case concept!
    (if you could send the .skp to my e-mail that would be great. If you wish to hold on to them for the time being that is fine as well)
  6. ajampaniki
    14 May 2003
    So how many entries did you get up to know? And could u post some more maybe?
  7. Joungne
    Joungne What's a Dremel?
    11 Jul 2004
    Alchemy entry from Joungne
    Hi Guys,
    time to reveal what I have been up to the last few days.
    I hope you like it :)
    @ Static Lullaby : I will email you all the highres renderings and some explanation with the design tomorrow.
    about the Ipoddock. Its a modular design so in its place their couldbe a lot of other modules like a passive design for cooling : a large heasink. Or just a plain plate so you get infact a reversed window. The side is a total window with a plate in it ;-) .... So much possibillities
    greetz,
    Joungne
  8. Soul__Assasin
    Soul__Assasin What's a Dremel?
    21 Oct 2004
    Great design dude.
    You do have the skilz to win this
    Good luck to all
  9. ajampaniki
    14 May 2003
    Ok you suck man my images will look like **** compared to yours :(
    Nah just kidding they rock man. What program did u use for that?
  10. Joungne
    11 Jul 2004
    they are made with 3dsmax and Metal Ray
    greetz,
    Joungne
  11. Static Lullaby
    1 Feb 2006
    Very nice work! I really like the I-pod dock idea. It all flows so well!
  12. Static Lullaby
    1 Feb 2006
    Lots of other really nice submissions have been put in so far. While I have to admit Joungne has gone above and beyond in the detail of his artwork. We are looking at all apects of the case as a whole, and can envision the final work of many of these cases beyond what their images may or may not protray:D
    Everyone has a good shot @ this contest! 2 days left... let's get those last minute entries rolling in too! :rock:
  13. freemc
    freemc What's a Dremel?
    20 Feb 2006
    other contests?
    I only see this now, so it is too late to make a decent design. I would be interested in doing something like this though. Do you plan any other design contests? Like for HTPC, barebones, ...?
  14. Static Lullaby
    1 Feb 2006
    Even if you could get in a rough draft of the concept you have, we can get a pretty solid idea of the design. We have MANY submissions in all formats. Some as simple as handdrawn sketches that were scanned in. If you have the time to get somethign done, feel free to submit your entry.
  15. xrain
    xrain Minimodder
    26 Jan 2004
    IM GOING IM GOING, I can only Sketch up so fast :worried:
    edit/ Does the It end At 12PM Tuesday or 12PM wensday /edit
  16. dutchcedar
    24 Oct 2004
    The more conventional design... :hip:
  17. LockmanX
    LockmanX What's a Dremel?
    8 Jun 2003
    This, I have to admit, is pretty damned cool.
  18. Static Lullaby
    1 Feb 2006
    That is indeed a very nice looking setup there!
    Could I trouble you for the .skp files? :)
    **note: we are only using any 3d renders sent to us so we can get a good view all around the designs and have a 100% full version of the renders**
  19. Brubacker
    Brubacker What's a Dremel?
    23 Oct 2004
    So , I've managed to get 6 designs ready ...
    not 100% in detail because of the lack of time :)
    I'll submit my 3 best designs :)
    now going to look for a webhost.
  20. Static Lullaby
    1 Feb 2006
    Awesome! Can't wait to see what you have in store for us!
