A challenge
Discussion in 'Hardware' started by Bluephoenix, 1 Feb 2008.
  1. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    a challenge for all of you who know your hardware.
    what is the cheapest computer you can build that meets the following requirements:
    8800GT GPU
    at least 2.7Ghz C2D or C2Q (must be standard, as the parts must be under warranty)
    Decent case (none of that $50 break on unbox BS)
    a 2-4 port Hardware RAID card is not necessary but is a plus
    keep in mind US pricing (meaning $ and not GBP) shipping is irrelevant.
    I know these threads are normally common and most of you usually reply with this nice little smiley: :search: but this is a simple challenge for those who wish to take it.
  2. radodrill
    radodrill Resident EI
    14 Mar 2006
  3. Bluephoenix
    3 Dec 2006
    very nice
    one question though, since I haven't been keeping up with things very much.
    does the NF700 series support peynryn or not?
    now the big question is, can anyone beat that?
    *que bad limbo music*
  4. radodrill
    14 Mar 2006
    Yes, they do support the 45nm CPUs. But I read quite often that the intel chipsets are better and the only reason to get a board with an nvidia chipset is for SLI support.
  5. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    It does seem odd to me that Intel would only support AMD's Crossfire. To me, it should be the other way around. Intel chipsets should support SLI, not the competitions solution.......but hey, what do I know?
    Can't really do much better than radodrill did, though I'm not crazy about the Gigabyte mobo. The E8400 is about $15 cheaper at newegg, but that's just squeezing a few pennies. Nice to see someone else that shops at ZZF.
  6. naokaji
    naokaji whatever
    8 Dec 2006
    intel does want to support sli, but nvidia doesnt allow it so they can sell mainboards as well.
  7. Guest-23315
    Guest-23315 Guest
  8. radodrill
    14 Mar 2006
    nVidia does not license out their SLI technology to chipset makers so that they can have a monopoly on SLI boards.
    I've heard a lot of good things about the Gigabyte P35 boards; that said, I'm running a DFI LP 680i.
    Sure some things can be a bit cheaper here or there, but when considering shipping costs it's only worth it if there's a substantial price difference.
    I shop all over the place; Newegg, ZZF, Tigerdirect, PCMall, ClubIT, etc.
  9. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    cant you get a mobo with onboard raid? That should cut down on costs a wee bit
  10. Krikkit
    21 Jan 2003
    Yes, for that system a 520W Corsair is plenty.
    Onboard RAID is much slower - if speed is critical then there's no point, otherwise, yes. :)
  11. Bluephoenix
    3 Dec 2006
    the person wanting the system wants to possibly do dual-gpu in the future
    have there been any major issues with the reference boards this time around?
    I'm still looking hard at the striker II, because I'm familiar with the original.
    and any onboard RAID is likely to be SoftRAID that relies on drivers.
    even the cheaper RAID cards on the market are all SoftRAID
    that said, I talked the person wanting the system out of the RAID requirement because the only cards that do true hardware RAID are $100+
  12. Squadexodus
    5 Jan 2008
    COOLER MASTER Centurion 5 $44.99
    Intel Core 2 Duo E6750 Conroe 2.66GHz $189.99
    ASUS P5N-D $149.99
    XFX PVT88PYDF4 GeForce 8800GT $259.99
    G.SKILL 2GB $46.99 Western Digital Caviar 80GB $44.99
    Rosewill RP550-2 550W 66.99
    $756.94
    You did say cheapest right?
  13. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Seriously, do NOT go for a Rosewill PSU. They're really bad quality. It'll sooner or later (propably sooner) kill the other components of the computer...
    Even if it's a lot cheaper, it's not worth to risk.
  14. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    You will save shorterm going with a cheap psu but longterm, replacing all the components will be what you have to do if you have a cheap psu.
  15. radodrill
    14 Mar 2006
    I'm not fond of rosewill power supplies either.
    The power supply is one item where you don't want to skimp.
  16. Bluephoenix
    3 Dec 2006
    updated challenge:
    Peynryn tech if possible
    min of 2.6Ghz
    SLI Motherboard and PSU capable of handling dual 8800GTs in the future
    8800GT
    Minimum of 2 HDDs of at least 160GB+
  17. radodrill
    14 Mar 2006
  18. Squadexodus
    5 Jan 2008
    Well, there goes my cheap computer.
    I drop out of this challenge, because i dont feel like it.
    I let you guys know if my rosewill fries my motheboard
