Graphics A couple of RTX 2080Ti questions.
Discussion in 'Hardware' started by Kronos, 7 Feb 2019.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I think I am going to treat myself to a RTX 2080Ti but want to know should I also upgrade my CPU and PSU.
    Specs here.
    GA-Z170-Gaming K3/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/500Gb/ Samsung 256Gb M.2/OCZ TR150 SSD/2 x 256Gb SSD/ 2TB HDD/ SST-ST60F-P PSU/
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    None of those would be any issue with the 2080Ti. 600W is more than sufficient power for the whole rig, and the 6600k is not going to bottleneck any game. For gaming, any upgrade (which would be CPU + motherboard, and +RAM if switching to RyZen) would not provide appreciable performance gain for the cost of swap. If you're intending to use it for more than gaming, and the applications you intend to use benefit from more cores rather than faster cores, then a CPU upgrade may be useful.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks, I might ask for a 2080Ti build suggestions including monitor and see what suggestions I get.
  4. Vault-Tec
    30 Aug 2015
    Yes with that CPU I would say you have more than enough juice on tap.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers Andy.
