A different Raidmax 868 case [7/9]
Discussion in 'Project Logs' started by Marius_EV, 19 Jul 2005.
  1. Marius_EV
    Marius_EV What's a Dremel?
    19 Jul 2005
    I've been tired of the design on my Raidmax case for a long time now, and it's time to do something with it.
    Sorry for my english, I hope it's understandable. :)
    This was my almost standard Raidmax 868 case for about a year ago:
    Then the evolution:
    The last months it has just looked like crap.
    The Plans
    Sketchup of the case:
    This will hopefully be a case with good cooling and with clean design.
    Then to the work
    Of course I need my computer during the project.
    A stripped Raidmax case:
    The front:
    Some shopping done 2 steelplates and some other stuff.
    I got 3x120mm fangrills for free from www.hcs-electronics.no.
    Thanks to them. :thumbup:
    Front and back ready for cutting:
    If you don't have the proper tool, you have to improvise. :)
    The front is to short. :duh:
    I'm sure i will find a solution.
    closeup
    Just trying out things.
  2. Marius_EV
    19 Jul 2005
    Some more shopping done.
    Bad "in action" picture.
    cheap ones
    a bit more expensive.
  3. Marius_EV
    19 Jul 2005
    New motherboard, I hate the one I got now.
    inside
    Outside (backside)
    four screws in.
    Four additonal screws down at the buttom.
    Two new holes in the middle
    Fits perfect. :)
    More to come.
  4. Wesker
    Wesker What's a Dremel?
    26 Sep 2004
    How are you going to hook the motherboard up? Other than that it looks like its gonna be great!
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Very clean. Nice plans (especially the air flow thingy)...
    :~subscribed.
  6. Marius_EV
    19 Jul 2005
    It's hard to explain, but easy to do.
    I'm sorry, you just have to wait and see. :)
  7. Kverna
    Kverna What's a Dremel?
    6 Jun 2004
    looks good Marius! Keep it coming
  8. frodo
    frodo What's a Dremel?
    1 Nov 2003
    wow, that case is very shiny!
    looks promising, i like the idea of the angled motherboard :D
  9. horgboy
    horgboy haisup
    25 Mar 2005
    shinyyyyyyyyyy angled motherboard looks cool
    great airflow also
    btw, ur enlgish is fine i have no trouble understanding it
    keep up the great work
  10. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Kill it.
    Marius, rare-ish name. My best buddy shares your rareness. :p
  11. mediacoretex
    mediacoretex What's a Dremel?
    28 Feb 2005
  12. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Looks promising... Let's see more!
  13. Marius_EV
    19 Jul 2005
    heh, it's a quite common name in Norway, and i can understand wy it's not common in Denmark, it sounds strange in danish.^^
    The tilted motherboard has many functions:
    - Looks good
    - Big space at the back to hide wires etc
    - The graphic-card si then placed in the middel of the airflow
  14. Marius_EV
    19 Jul 2005
    Update 21/8
    Update finally :p
    I will write some comments to the pictures later.
  15. Marius_EV
    19 Jul 2005
  16. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Oh man, I would like flip the mobo to get the cpu underneath and the vga on top, that way WITH the leaning motherboard you will see the beautifull side (fan-side) of your vga? pimp up your vga for that ofcourse..
    Or is to big of a hassle to change plans/sides?
  17. Marius_EV
    19 Jul 2005
    That would have looked nice, but first I have to figure out the connections to the mainboard. If I find a practical solution, I may do it.
  18. I see what I like and I like what I see ;)! This is what Raidmax SHOULD be proudcing. And those gold fitting look the shiznit! :thumb:
  19. Marius_EV
    19 Jul 2005
    They came with the plexi, but i don't know where to use them yet.
    I don't think it wil be any problem to find a use for them. :p
    Edit: How do i change my Avatar? I can't find it on the CP.
  20. Marius_EV
    19 Jul 2005
    Update 28\8
    Upsidedown, hmm
    The nuts are not tightened
    The harddisk will be attached here with some black plexi
    I'm not sure where I will put the radiator yet.
    This position is not the best for the airflow, but with 2 fans on the radiator I think it will do ok.
    This have to be black.
    I think I must make a bigger window in the sidepanel.
    Should I do someting like this?
    Cut out the marked areas and put som black plexi behind?
