Modding A Eheim 1048 how many db does it make?
Discussion in 'Modding' started by cgsimons_2000@yaho, 19 Jan 2004.
  1. cgsimons_2000@yaho
    cgsimons_2000@yaho What's a Dremel?
    12 Jan 2004
    Is it possible to modd it in a bok with sound proof meterial, or will the pump over heat or will the water cool it down?
  2. cgsimons_2000@yaho
    12 Jan 2004
    A
    Are there any Uk web shops that sell cutom buildt Vapochill watercooling kit?
  3. wharrad
    wharrad What's a Dremel?
    26 Jul 2003
    Been thinking about sticking my 1250 in a box with sound proofing and keeping an eye on the temps - I'll get back to you if it's any good
  4. cgsimons_2000@yaho
    12 Jan 2004
    Yeah do that.
    Anyone else that have any problems with Eheim and sound?
    Anyone tried to moddit in a soundproof box?
    Does Eheim 1250 make more sound than eheim 1048?
  5. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    I have a 1048 and its silent without any padding.
  6. skyrex
    skyrex What's a Dremel?
    22 Dec 2003
    i think that to a point the noise output of the pump will depend on how hard you have it working... i.e. if u have it cooling cpu, chipset, gpu, and passing thru a big-ass rad and a rez... then u can imagine how hard it is working to push water around thru everything...
    where as if its only cooling cpu and going thru 120mm rad, rez there is generally less 'stress' on the pump to push the water thru so many parts...
  7. cgsimons_2000@yaho
    12 Jan 2004
    SO when I will have a full set with cpu, ND GPU etc and a dobble 120 mm rad.
    Would it then be better to buy a 1250 Eheim pump instead of 1048??
    Can u controll the speed of the pumps?
  8. TetarZ
    TetarZ What's a Dremel?
    16 Dec 2002
    If you immerse your pump (put it in your res) you willl be able to put sound deadning material. As for the pump noise depending on how much stuff you have in you loop I don't think it's true.
  9. wharrad
    26 Jul 2003
    If you're gonna have alot of stuff in there, I'd go for the 1250.
    That's why I went that route - got water cooled PSU, NB, 2 hard disks - res and big rad (not that it's all installed yet... but who's checking, the PSU will never arrive). The only thing was that I'm running out of space and the damn 1250's biggggg
    don't www.overclockers.co.uk sell the vapochill watercooling stuff?
