A few beeps, no booting.
Discussion in 'Hardware' started by Noah, 20 Feb 2004.
  1. Noah
    Noah What's a Dremel?
    8 Feb 2004
    I have an old computer I took apart and then put together. Now when I try to turn it on, I get a few beeps, but nothing activates. Keyboard lights flash but then are blank. Monitor is not activated. What's up?
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    What sequence of beeps do you get?
  3. Noah
    8 Feb 2004
    beep beep beep
  4. Highland3r
    25 Jul 2003
    :eyebrow: :eyebrow:
    Are they long, short, 2 toned, mono tone?
  5. Noah
    8 Feb 2004
    2 of them are short, one is a slight bit longer. And it re-beeps once after a while
  6. savethegaywhales
    savethegaywhales What's a Dremel?
    17 Feb 2004
    Who is the manufacturer of your motherboard? Look up their support site and see what the beeps mean.
  7. Noah
    8 Feb 2004
    :waah: Concluded with a friend that it's the video card. What could be the matter? :waah:
    See attached pic. I have a few things disconnected, as you can see. Is it ok that they are not connected?
  8. woodshop
    woodshop UnSeenly
    14 Oct 2003
    cool looking card. it's eather old or like a renderig card. tis cool though. do you know what the spots are for? the one looks likr a ide header the other looks like a memory slot.. nice sry can't help though just wanted to say that
  9. Noah
    8 Feb 2004
  10. savethegaywhales
    17 Feb 2004
    According to this it would appear that the BIOS can not initialize a video screen. Try it with a different video card and see if it works.
  11. Noah
    8 Feb 2004
    I have an 8x AGP card, that is a 2x card. This is a 5-year-old computer. Would the 8x work?
  12. savethegaywhales
    17 Feb 2004
    I'm pretty sure that it won't work. Do you have anything else?
  13. hypocrisy86
    hypocrisy86 Banned
    27 Jan 2004
    yea it wont work but you can try though.
  14. SnipeHunter
    SnipeHunter What's a Dremel?
    20 Feb 2004
    It is your RAM lol i did the same thing a bit back try reseting your bios and make sure your ram is in right.
  15. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    hehe, i dont know why but this thread made me laugh (it reminded me of vintage benny hill at the beginning) lol
    Ok firstly, open up your case and study the motherboard for a model number. You need to find out exactly what it is, then try to d/l the manual for it. You should be certain what the beep code means before attempting anything IMO.
    If it is a GFX card problem then a new card may or may not work. There is more than one AGP standard (not the 2x, 4x etc). If that GFX card is AGP 1.0 then chances are it wont work with your new one (in fact it may fry your new one). The motherboard manual will tell you what standard it complies to. Your 8x card is probably an AGP 2.0 standard, it uses less volts (about 1/2) so you can see the potential dangers.
    If i were you i'd get the manual and start diagnostics again, but its definately worth resetting the CMOS and reseating everything.
