Cooling a few wc questions
Discussion in 'Hardware' started by dan-ere-07, 17 Feb 2008.
  1. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    i am planning a wc setup for my mod and i was wondering a few things
    i have a 8800GTS
    would the universal version
    http://specialtech.co.uk/spshop/customer/product.php?productid=5034&cat=578&page=1
    work as well and fit as easy as the real one?
    http://specialtech.co.uk/spshop/customer/product.php?productid=3388&cat=578&page=1
    and witch pump would be better?
    http://specialtech.co.uk/spshop/customer/product.php?productid=2112&cat=537&page=1
    or
    http://specialtech.co.uk/spshop/customer/product.php?productid=1954&cat=537&page=1
    also
    would a ThermoChill PA120.2 Dual Radiator be ok to cool my gpu and cpu?
    in
    res > pump > CPU > GPU > rad > res agen?
    thanks for any help
  2. radodrill
    radodrill Resident EI
    14 Mar 2006
    If you have an 8800 GTS 512 then you need the 8800 GT G92 block (first link) if you have either the 8800 GTS 320 or 8800 GTS 640 then you need the 8800 GTS block.
    I'd go with the ultra model of that pump since it has a higher flowrate and higher pressure head.
    for CPU + GPU a 120.2 should be enough, but I personally would rather go with a 120.3
  3. dan-ere-07
    29 Mar 2007
    thanks for the help rad
    mines the 640 so ill go with the 2nd one then.
    and i have got a hole in the front of my pc for the 2.120 already but i could put another somewhere in the case
  4. tomshawn
    tomshawn What's a Dremel?
    7 Mar 2008
    first of all - change gpu to 512MB :)
    go with Swiftech mcw60 as gpu block, pretty universal, you can change your card alter and block will stay. Then swiftech radiator - 220 is enough. If you notice later that its not enough, then add another 120mm rad. Or if you can fit 3x120 rad in your case, then go at firstplace...
    both pumps are ok. Get rid of res in your loop. They useless...
