A/V A good 2.1 speaker system for PC & XBONE
Discussion in 'Hardware' started by DIZZY DAZZLER 2010, 23 Oct 2014.
  1. DIZZY DAZZLER 2010
    DIZZY DAZZLER 2010 Tech nut!
    23 Feb 2010
    Folks
    Can anyone recommend a good 2.1 system that allows two inputs for Xbox one and PC. Budget is not a major issue but I need best bang for buck with a system that doesnt take up loads of room.
    I have considered a 5.1 system to replace my dead Sony SA WBE1 but the only thing I can see with two optical inputs is the Logitech Z906 but its not cheap!
    Optical input is my preferred connection but I have not seen it on any 2.1 systems so I may resort to the usual 3.5mm input.
    Thanks in advance
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Not a 2.1 set but the Microlab Solo9C's have Optical, 2xRCA, HDMI and Coax inputs. They should have more than enough oomph in the bass department, despite the lack of subwoofer.
    The Solo8C's also have the same inputs minus the HDMI and are a bit cheaper.
    Edit: Found a 2.1 set with Optical and Coax, Microlab M910. They're EOL now though.
  3. johnim40
    johnim40 Minimodder
    23 Apr 2009
  4. DIZZY DAZZLER 2010
    23 Feb 2010
    Checked out the microlab stereo speakers but they are a tad too big for me. Need something a little smaller.
  5. Big_malc
    Big_malc Minimodder
    7 Sep 2010
  6. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    A bit expensive, but the Klipsch promedia 2.1 speakers are great.
  7. DIZZY DAZZLER 2010
    23 Feb 2010
    Do like the look of the gear from microlab. Was tempted by the m910 due to the optical input, however there does not seem to be a headphone output.
    Now considering a denon m39 and some small but competent speakers.
