Planning a little water cooling help
Discussion in 'Modding' started by Tec_, 23 Aug 2009.
  1. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    well guys im re vamping the water cooling in my case and im going to be putting in new hoses and new compression fittings. im currently using mct-5 for for coolant.
    any suggestions on better coolant? or should i stick with the mct-5?
  2. H2O
    H2O Burnt Acrylic - Mmmmmm
    1 Aug 2009
    Depends on who you ask. I use Feser One and absolutely love it. Others will tell you to go with distilled water and additives.
