Scratch Build – In Progress A mITX build for my mom (19:th October, Soon finished, some overall images)
Discussion in 'Project Logs' started by Mr3D, 5 May 2012.
  1. Mr3D
    Mr3D What's a Dremel?
    23 Dec 2011
    Some of you may remember me from L3p L4n build, i designed the Mars II waterblock. Anyways, now I'm making a mITX build for my mom.
    I'm planning to use a ASRock Z77E-ITX motherboard with a low power Sandy or Ivy CPU, a HD 7750 GPU (Or NVIDIA similarity). This will be a scratch build (pic below)
    Okay, so let's begin!(I actually started some weeks ago but created the thread now) :clap:
    Got myself a package! :D It is a 150w Pico-PSU and a 120W AC-DC converter.
    And some connectors and buttons too. :rock:
    So the first thing i did was to exchange some of the connectors on the brand new PSU... :duh:
    I like the result! (More connectors will be exchanged later.)
    And a package from Nils! :eek:
    So i got a Slim DVD without faceplate from eBay...
    ...what i didn't know was that it came without a eject button. :duh:
    I need to fix that, and i think the cables to the button should be soldered there somewhere. Need to pull out my DMM and measure some spots so i can find the solder points for the eject button.
    And i can probably solder some LEDs there. :geek:
    Got a Slimline SATA cable too! :D
    But i can't stand the color so let's exchange the cables to black ones! :dremel:
    Here is the housing.
    And all the pins and stuff. Will hopefully solder new cables this weekend. :thumbsup:
    Cleaned the caps! :D Need to buy black paint so i can paint the connector. :)
    Hope you like it! :D
  2. l3p
    l3p www.^.nl
    1 Nov 2010
    I will be his first follower! :)
    This guy rocks with his cam :thumb:
  3. jhanlon303
    7 Sep 2006
    Good start. I watch how you will do SATA cable.
    john
  4. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Lovely start !
  5. Mr3D
    23 Dec 2011
    Thanks guys! Glad you like the pics Peter. :D
    Okay, so a small update. Oh, and Peter helped me with the links so you can klick the image for a bigger image(around 3000px). :eeek:
    Now i need to buy black paint so i can paint it black! :D
  6. KidMod-Southpaw
    28 Sep 2010
    Great start, loving this! :thumb:
  7. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    why just not but a connector from stefan or nils ?
    Subbed and +rep :)
  8. Mr3D
    23 Dec 2011
    Thanks guys!
    Kosovar: Because it wont fit. The pico 24-pin is smaller than a regular 24-pin. ;)
  9. Mikhail
    Mikhail What's a Dremel?
    5 May 2012
    I think it'll be a great gift =) Unique in the world. Besides, great pics like always and when I look at how you dissassemble everything like you're playing with a kid's toy...it's just great. Awesome and keep going!! Will be following this closely!
  10. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    good start, im following! =)
  11. KoSoVaR^
    19 Dec 2010
    Ahh yes you are right :), go and buy some black Plastic Dye and boil the connector into the dye 2-5 minutes :)
  12. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Sub'd
    Looking forward to this :thumb:
  13. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Suuuubbed - this can't become anything but good.
  14. Mr.Evil
    Mr.Evil What's a Dremel?
    7 Feb 2012
    very interesting !
    love mini itx :thumb:
    the drawing is made with solidworks ?
  15. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    paint will chip quickly mate, you might trying a RIT dye or something or (if you can find it) there is a product by Plasti-kote called Ultra Vinyl Dye that is fantastic. I've used it before but it can be hard to find. The product softens the plastic and causes the material to open up (like pores on your skin) and it absorbs the color from the product.
  16. Mr3D
    23 Dec 2011
    Thanks guys! Love the positive feedback! :blush:
    Sixfoot: Kosovar showed a site where i can buy dye so that is ordered. I think it was called iDye or similair. :)
    Okay, so small update before i go to bed. :)
    The slimline SATA cable is done! Turned out OK, could be better tho.
    The molex part will be removed, that one is just for testing.
    Soldered.
    Glue.
    Finished. As i said, it is only okay. :)
  17. Nutman
    21 Oct 2008
    I think it looks fine, but when you HAD the plug opened, why didn't you expand the holes around the cables a bit and then concealed the ends of the sleeving INSIDE the plug? In that way you could have eliminated the need for heat shrink for that end of the cable.
    But you're perhaps not going to use sleeving at all?
  18. Mr3D
    23 Dec 2011
    I will sleeve some of the things but not this because it won't be seen anyways. :)
  19. Sutura
    Sutura What's a Dremel?
    23 May 2011
    Ontopic: Thumbs up for the commitment and the hard work. I would never go about soldering my slimline SATA cable :D
    Offtopic: Do you mind if you share with me the thought process behind choosing a mITX for your mom? To clarify: I was thinking that my parents need a new PC, instead of the bulky 775 ATX machine they have now. They have pretty basic needs: firefox+word+skype, not even watching HD movies. And I was wondering between mITX and laptop or netop. And I started leaning towards a laptop. So now you see. It'd be nice to hear someone else.
  20. Mr3D
    23 Dec 2011
    Thanks mate! :D
    How about a i5-3570K for your build?
