Scratch Build – In Progress A mITX build for my mom (19:th October, Soon finished, some overall images)
Discussion in 'Project Logs' started by Mr3D, 5 May 2012.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    All of this cute (with permission) SFF voodoo scares me! I need to read up more on it all!
    I like the way plain black cables look :)
  2. Mr3D
    Mr3D New Member
    23 Dec 2011
    I Sweden we have both Sapphire and PowerColor low profile 7750. :)
    http://www.komplett.se/k/ki.aspx?sku=757651
    http://www.komplett.se/k/ki.aspx?sku=757637
    Thanks! And good luck to you too, with your project. :)
    Permission granted. I too think it is really cute. :)
    Thanks! :thumb:
  3. Mr3D
    Mr3D New Member
    23 Dec 2011
    Here, have a small update!
    So i played with my schools CNC Lathe! :thumb:
    This is what i did: I bought some M3x45mm screws, lathed 4 distances and 4 feet's. :D
    The feet's turned out great! Made out of POM. :rock:
    The feet fully assembled. Tho it is missing a motherboard and a case. :nod:
    All the parts: POM feets, M3x45mm screws, motherboard distances and rubber feet's, i will mount the rubber feet's inside the hole of the POM feet's to reduce vibrations. :)
    Hope you like this small update! :D
  4. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    OMG, how much would you take for a pair of feet for my prodigy ?
  5. Mr3D
    Mr3D New Member
    23 Dec 2011
    Non-important Swedish talk: Beror på storlek och vilken tid det tar, men jag borde kunna göra de för runt 6-700kr + frakt. Då får du de helt custom byggda(Jävligt billigt då svenska CNC operatörer tar ~600kr timmen, de jag svarvade tog ~5-6h innan jag kört in maskinen och kört klart de). :)
  6. KoSoVaR^
    19 Dec 2010
    Sounds good my friend :)
  7. l3p
    l3p www.^.nl
    1 Nov 2010
    You did it!
    Nice result Daniel :)
  8. Mr3D
    Mr3D New Member
    23 Dec 2011
    Yes i did! :D Thanks Peter!
  9. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Wow, I really need to drop in an visit b-t a little more often. Great looking project man! You can never have too much SFF goodness! :D
  10. Dk_vr
    Dk_vr New Member
    18 Apr 2012
    Really nice result :)
    Keep the good work
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Awesome. Keep it up!
  12. Guest-23315
    Guest-23315 Guest
    Bump for updates.
    Please? We need our fix already.
  13. Mr3D
    Mr3D New Member
    23 Dec 2011
    Fine! Here you go.
    I'm really close to finishing this build. I'll let the images speak for them self. :)
    I also made a video about the installation/assembly process, enjoy. :)
    A mITX build for my mom - VLOG#01
    Fifas likes this.
  14. Mr3D
    Mr3D New Member
    23 Dec 2011
    Time for a small update, this time, i exchanged the SMD LEDs on the card reader PCB to white ones. :)
    Before:
    After:
    I made a video about the soldering process, enjoy it in 1080p. :rock:
    A mITX build for my mom - VLOG#02
  15. Editor22
    3 Jan 2009
    Much better
  16. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Such a nice build man, loving the work! :)
  17. Fifas
    Fifas New Member
    6 Sep 2012
    Love this small projects!
    Really good. Well done ;)
  18. dreps
    dreps Member
    3 Oct 2012
    nice skill there! keep up the good work :D
  19. Rygel Cumberbatch
    Rygel Cumberbatch New Member
    21 Aug 2011
    I can tell that I'm going to really enjoy checking back on your work from time to time :D
  20. KoSoVaR^
    19 Dec 2010
    Great Daniel, are you going to use some shorter sata cables ?
