Build Advice A Mobo and a GPU Needed
Discussion in 'Hardware' started by Anthias, 3 Aug 2011.
  1. Anthias
    Anthias What's a Dremel?
    25 Dec 2010
    Budget: No Limit, but I want to spend sensibly.
    Main uses of intended build: Gaming.
    Parts required: Motherboard, GPU
    Monitor resolution: 1080p
    Will you be overclocking: No.
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): May SLI if sensible. Four fan headers required.
    Extra information about desired system:
    The parts I have so far:
    Corsair Obsidian 800D
    1500 W Power Supply
    i7 980X
    6 GB RAM
    3 TB HD, 256 GB SSD.
  2. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    As far as mobo goes, I believe the Asus Sabertooth is favoured for Socket 1366. Stable and generally problem free, while not breaking the bank. (Just going on what I have read from others and Bit Tech)
    With a PSU like that, are you looking at a SLI/Crossfire setup?
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm still wondering at buying a 980X and not OCing. A stock Intel business board would suit at that point, and be so much cheaper, but there's no point in having an unlocked processor and doing nothing with that extra $500 or so price premium for the 980X.
  4. Guest-16
    Guest-16 Guest
    Mobo: Rampage III or Sabertooth.
    What's your CPU cooler? and what PSU do you use that's 1500W?
    With something like a Corsair H50, even just increasing the multiplier to 4GHz will be a nice, easy OC on either board.
  5. Anthias
    25 Dec 2010
    Okay, overclocking is an option then. I have a Corsair H70 for the CPU. The PSU is a Silverstone sst-st1500.
    There are many different Rampage III's it seems. Is there a serious difference between them?
  6. Guest-16
    Guest-16 Guest
    The III Extreme is last summers ROG board - the first to use DIGI+ VRM, while the III Black Edition is this years with a couple of small upgrades and a colour change. You can buy it with or without the ThunderBolt Xonar/KillerNIC combo card. :)
    As far as general features and OCing goes, no, no huge difference.
  7. KayinBlack
    2 Jul 2004
    With that setup, yes, grab an easy 4GHz.
    I'll second Bindi's recommendation. My pick has gotten so rare that you may as well go with a newer and easier to get board.
  8. Krony
    Krony What's a Dremel?
    30 Jul 2011
    I use the Sabertooth X58 and it's a great board, as for a gpu i would get a 580.
