Modding A mod or a project?
Discussion in 'Modding' started by jhanlon303, 14 Feb 2011.
  1. jhanlon303
    7 Sep 2006
    Is it a candidate for modding forum or project logs when one is modding a case to a theme but with no real hardware goals in mind.
    Lighting, airbrushing, engraving, CNC, etc.
    Like my Notalis case from Bill and E.E.L Ambiense. No hardware, just a case mod.
    john
  2. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    Definitely, the hardware doesn't (or shouldn't) make or break a mod. So I'd say there is 0 need for hardware to be involved at all. I just usually is as people like to use the mods they work so hard on.
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    It's still a project, and the case is the more interesting part anyways. The hardware you stuff into it later on is rather irrelevant imho and is subject to being changed once in a while, whereas the case itself stays basically the same over the whole time.
  4. Cheapskate
    13 May 2007
    GwassGween went a full year without hardware. There's still nothing but cooling parts.:D
    If you're building a computer case mod, why is the hardware needed to qualify as a log?
  5. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Deffo hardware irrelivant in many cases
    My Monster2 build was actually only meant to be a case build only, was only by pressure from freinds to stick some hardware into it.
    Was more than happy using Monster1 pc, afterall i only really use forums and msn.
  6. bulldogjeff
    2 Mar 2010
    Cast your mind back a few years John, it was all about the mod and the hardware was usually low spec and just in there to qualify it as a PC not a pretty box. Things have changed now with watercooling and high end gear all being part of the over all build. I will admit that seeing a project fully up and running does it for me, but thats just me wanting to see the finished article in all it's splendor.
