Modding A problem of space...
Discussion in 'Modding' started by NOMIS, 30 Mar 2005.
  1. Pezboy
    Pezboy What's a Dremel?
    12 Oct 2003
    Are you using H-molding or C-molding? It looks like C-molding would fit on there, if with a bit of trimming, and then you'd just have to glue the window on with some epoxy. No fan mods at all.
  2. Godboy_g
    Godboy_g What's a Dremel?
    13 Aug 2004
    What you could do, although it may be a bit challenging. You could cut the case, and mount the fan half inside the case, and half outside. you could then build a shroud on the outside of the case to cover the bit showing.
    Something similar to the following:
    http://www.reverie.ltd.uk/shop/products.php?p=106d05
  3. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Yeah I'm using H-moulding. Would I glue the plastic to the metal, I reckon that would look at bit weird :/
