A Puzzle: How many Petals Around the Rose?
Discussion in 'General' started by QuickOrbit, 27 May 2004.
  1. QuickOrbit
    QuickOrbit What's a Dremel?
    27 May 2003
    Here is something that you all may enjoy. ::Evil sadistic laugh::
    The only hints that you are allowed:
    The answer is always even or zero
    The name of the game is important
    Evidently it took Bill Gates 2 1/2 hours to get this right. Some people get it right away, and some take years to figure it out.
    Good Luck and NO POSTING THE ANSWER!!!!!!!!!!!
    Enjoy :D
  2. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Clever, yet managed to suss it inside of a minute. :)
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Man, got it right first, second and third time. So I assume what I thought it meant was right.
    Does that mean I am infintly more clever than Bill???
  4. woodshop
    woodshop UnSeenly
    14 Oct 2003
    Yea!!! inside a min figured it out second roll. :D
  5. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    Figured it out pretty quick, didn't help that I clicked roll instead of check a few times :wallbash:
  6. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    i hate **** that makes me feel stupid :confused: jsut makes me angry
  7. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Solved :hip:
    Hint: Forget maths for a bit. Write down on a piece of paper all you know about the game taking the title of the game into consideration.
  8. Pookeyhead
    30 Jan 2004
    he he... took me a couple of minutes to work out what to do.
    that's sneaky.
  9. Krikkit
    21 Jan 2003
    Grr :grr: that's annoying - i managed to get it the first two times, now i just can't do it :duh:
  10. SJH
    SJH Minimodder
    24 Dec 2003
    Took me a couple of minutes too, but I figured it out (surprisingly, I can never do these things!)
    -Sam
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    managed that in about a minute, lucky guess more than anything to start with.
  12. Skutbag
    Skutbag What's a Dremel?
    17 Dec 2003
    Got it. Need a bit of lateral thinking. (if thats the right term)
  13. mushky
    mushky gimme snails
    24 Mar 2003
    i had two experimental goes, then tested my theory on the third + had it solved.
    thats a good game, cheers
  14. ajack
    ajack rox
    17 Apr 2003
    It bugged me for a minute or 2 then I got it :)
  15. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    I also got it 1st, 2nd, 3rd, 4th .... times i tried.
    I read the background first, looked at the question and thought WTF!? Maybe its this... I also usually take ages to solve these sorts of things
  16. westeee
    westeee What's a Dremel?
    20 Jan 2002
    that was easy :)
    i did a roll , read the question again , and got it from then onwards
  17. Arien
    Arien What's a Dremel?
    22 Jun 2003
    Got it at last.. bleeding heck lol.
    Gah i thought i had it.. :(
  18. [GiB]Grey M@a
    [GiB]Grey M@a What's a Dremel?
    13 Dec 2001
    very clever indeed :) time to confuse the members of staff around here.
  19. Arien
    22 Jun 2003
    Given up :sigh: Just started to annoy me in the end.
  20. [GiB]Grey M@a
    13 Dec 2001
    keep trying, remember the answer is only even or zero and the name of the game is very important :)
