A question about Gamestation
Discussion in 'Gaming' started by K, 7 Dec 2007.
  1. K
    K 528491
    31 Oct 2001
    A mate of mine wants to know if Gamestation log the serial number of a console during the transaction at the point of purchase. ie. Is it on the original receipt?
    Thanks for any help guys.
  2. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Out of curiosity, why does your 'friend' want to know?
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I know Game don't, or didn't a year ago. Not sure that helps though.
  4. BigD79
    BigD79 Gadding about...
    2 Nov 2007
    Doubt it, they'd have to do it manually as bar code wouldn't have that info. But your mates console would have to be the same SKU as the one on your receipt i guess.
  5. K
    K 528491
    31 Oct 2001
    Well usually a Serial on a product like a console will have it's own barcode that you scan after scanning in the UPC.
    My mate's got a red-ringed second-hand 360 with no receipt, but reckons it's originally from Gamestation anyways. Basically he was gonna use a mate's receipt to just swap it out at Gamestation instead of going through the ordeal of sending it back through Microsoft. This is where I chimed in and went 'Hey, we always scan serials of stuff at my place so you can't do stuff like this', so I was just interested in finding out.
    Someone else I know did this with one receipt no less than around 4 times at Game, for 4 seperate consoles.
  6. Jamie
    12 Mar 2001
    I'm on my third console from Game which is how I know they don't really check.
  7. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    I work at Gamestation so I can tell you that they don't (At least my shop doesn't). The UPC is scanned, nothing else. You'll be fine unless you try return a core with an elite receipt :p
  8. K
    K 528491
    31 Oct 2001
    I also reminded the guy not to try it with a machine with a newer manufacturer's date than when the original one was bought!
    Cheers for the info guys, especially the confirmation Cabe64.
