Memory a question about my DDR3 RAM
Discussion in 'Hardware' started by t4n6o, 10 Oct 2011.
  1. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    In my system I have the corsair Vengence Jet black ram - DDR3, when i bought it after doing some research i found it to be 1.5v but when i was looking at CPU-Z it says the FSB DRAM is 1.6 - see below
    am i right in asuming that the voltage for this RAM is 1.6 and not 1.5?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    FSB DRAM is not the voltage!
  3. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    And to elaborate on Blogins reply... :D
    DRAM Frequency: 800.xx -> This means your RAM is running at 1600MHz. This is because the RAM is DDR, in your case DDR3. DDR = Double Data Rate, so whatever the speed reported by CPUz is; you double it and that is your "effective" RAM speed.
    FSB:DRAM -> This is not your RAM Voltage. It is a ratio of FSB Speed to RAM Speed.
  4. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Download HWMonitor or something similar, that will tell you what voltage your RAM is running
  5. t4n6o
    16 Aug 2011
    I see, was only asking as i have seen videos online of people overclocking their RAM and ws thinking of giving it a bit more juice, but thought i would check on here before i did something that i would regret lol
  6. t4n6o
    16 Aug 2011
  7. xXSebaSXx
    21 Aug 2010
  8. t4n6o
    16 Aug 2011
    my HW monitor is different to yours then as my ram isn't on there
  9. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Noob. :D
    Open CPU-Z, click on the SPD tab, then select the sockets which have the RAM inserted; voltage is shown at the bottom of the 'timings table' ( whether that's actual/current or rated voltage I don't know ).
  10. t4n6o
    16 Aug 2011
    yes your right I am a noob as i am new to overclocking and the programs used, but yeah i looked at this and it does show 1.5v but like you said whether that's actual/current or rated voltage I don't know
  11. SuicideNeil
    17 Aug 2009
    You could always look in the bios.
  12. xXSebaSXx
    21 Aug 2010
    I see... HWMonitor will report different things depending on what sensors your motherboard has.
    I would do as SuicideNeil suggests. The BIOS part, not the CPUz "SPD" tab as that only shows what the RAM is rated for not the actual voltage being fed to the RAM.
    PS: Don't pay attention to SN either... he's just being a bit of a "grump"... more likely just pulling your chain. The only "dumb questions" are the ones not asked. You need to ask in order to learn. :D
    Go to your BIOS and make your way to the AI-Tweaker section... Scroll down until you find the DRAM Voltage; you'll find the number there. :D
  13. t4n6o
    16 Aug 2011
    thanks xXSebaSXx will have a look tomorrow before i go for the second day of my boring course, going to bed now as i have to be up at 5:30 in the morning
