TVs A question on Displays (PC / PS3)
Discussion in 'Hardware' started by wgy, 10 May 2010.
  1. wgy
    wgy What's a Dremel?
    28 Jul 2008
    Looking into buying a TV!
    I want to use it for PS3 and bluray mostly but also as a PC monitor in the future.
    I went to currys for a look and im now scared that the perfectionist in me is going to end up spending a grand on a tv. (street fighter will look tits though. :blush: )
    rough criteria:
    Full HD (with true blacks)
    32 inch
    DVI, HDMI, VGA inputs
    budget of £400-600
    I am looking, but overwhelmed, so i need some help to make an informed choice. any response would be greatly appreciated.
    also... whats this new led display technology like?
  2. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Try to get as many pixels as possible. That's what makes a TV high deff.
  3. ripmax
    ripmax Minimodder
    8 Apr 2010
  4. wormy
    wormy Minimodder
    16 Oct 2009
    +1 to ripmax - that Samsung B650 has had some very good reviews, though if you can stretch to LED (and check some reviews) they are reputed to give better pictures (more like plasma quality blacks and colours, from what I understand but without the screen burn and energy usage issues).
    My only addition - don't buy from Currys lol or any other part of that group (PC World, Dixons). Nor Comet. Play can be ok but if you want a shop, check John Lewis, Richer Sounds, Sevenoaks Sound and Vision.
    Of course, be very wary of how they look in shops - they will all be set differently and running off who knows what source.
  5. bulldogjeff
    2 Mar 2010
    To add to what wormy's said tesco and asda are 2 of the best for prices and returns and you can do the shopping while you're in there as well
  6. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    To give some general overview:
    LCD: Normally much cheaper, and look good with ambient light falling on the screen
    Plasma: More realistic colour reproduction than LCDs, and better blacks, more expensive and not as good with ambient light, but better in the dark
    LED LCD: Uber high contrast and bright colours, gives a very vivid picture, but colour reproduction isn't as accurate as plasma, and they're expensive. Also come in two types - side lit and back lit, the latter being superior and more expensive.
    So as always depends on budget and usage :) I use a Panasonic TX-P50G10
    Another tip: when browsing in shops, don't make any decisions based solely on what you see, unless it's a proper AV store with a proper demo in a proper room. The ambient light makes all the plasmas look poorer, the LEDs are colour overdriven to look striking, and they'll be run off different bluray players to make the more expensive ones look even better
    Finally, have fun hunting, all part of the fun :lol:
    wgy likes this.
  7. Frohicky1
    16 Apr 2009
    Oops, forgot this bit. Normal LCDs are lit by Cold Cathode Fluorescent Lamps (CCFLs), of the sort you can use to illuminate your case. Unfortunately, these give out a variety of wavelengths of light, so when liquid crystal tilts to let through green, say, it also lets through a little bit of purple, etc. The screen is also brightest where the lamp is, and not quite as bright inbetween lamps, so the brightness and contrast isn't perfectly accurate.
    LED LCDs use LEDs to provide the light. Because this is a quantum mechanical process, it's moreprecise - green LEDs give out green light. LEDs can also be turned off and on for each pixel, rather than for regions with the CCFLs. The edge-lit ones are slimmer because they need fewer LEDs, but they also have a slight halo of brightness around the edge and darkness in the middle. Backlit ones are even.
  8. wgy
    28 Jul 2008
    thanks for all the replies guys, very helpful.
    rep awarded.
