Modding A question regarding cleaning acrylic
Discussion in 'Modding' started by Vaz, 10 Apr 2007.
  1. Vaz
    Vaz What's a Dremel?
    23 Jan 2007
    Hi guys,
    I just placed an acrylic window in my pc panel. The problem I'm having is cleaning it. No matter what cloth I use it leaves it dusty/scratchy and sort of cloudy. What's the best way to clean it?
    Kind regards,
    Vaz
  2. mario_cell
    mario_cell What's a Dremel?
    30 Jul 2006
    I would use the liquid u use for washing your windows :naughty:
    I never did it, but I think it's the best way
  3. culley
    culley What's a Dremel?
    12 Jul 2006
    How big is the panel? I would use a dremel with the buffer bit attached on and if its not to big buffer all those scratches away.
  4. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Just get some of those tissues you clean glasses with... can be bought at normal supermarkets :)
  5. canucker
    canucker What's a Dremel?
    9 Sep 2005
    wow,been a long time since ive been around!!my loss for sure.
    this is what i do and it works great.
    before cleaning,spray the window with compressed air,less chance of little dust,grime etc scratching.
    use eyeglass cleaner,and a lint free cloth
  6. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    If you've got minor scratches, some Novus Polish is what you want. However, if it's just dust and streak marks you want to be rid of, any lint-free cloth will do. If you're really a fanatic, Kimwipes should do the trick. I've used them in labs where the transparency of a container is crucial.
  7. Vaz
    23 Jan 2007
    hmm it's 3mm thick acyrlic. I've tried kitchen paper, tissue paper, glasses cleaning cloth (even though my one is sort of weird) and it doesnt do a good job. The acrylic doesnt remain clear but goes like.. cloudly sort.
    I'm going to give the glasses cleaning cloth another shot. Perhaps my dad's cloth might do a better job!
    @culley - panel window is quite big.
  8. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    When one of my relatives was in hospital a while ago she found out that, that weird alcohol gel stuff used for sterilising visitors hands cleans glasses amazingly well. I dont know how it would work on acrylic, or where you would get something similair to it from but it might just work.
  9. Arkantos
    Arkantos What's a Dremel?
    1 Apr 2006
    you were saying the acrylic was going cloudy??
    were you using any kind of thinner / cleaner??
    as it is, acrylic is soluble in many organic liquids. so if you use them to clean, it will melt the plastic.
    best cleaner in my small opinion is water and liquid dishwashing soap.
    Ark!
  10. foxx
    foxx What's a Dremel?
    5 Sep 2004
    Do you not have windex in Europe? What I clean my acrylic/ windows/ monitor/ mousepad/ painted metal/ other random bits and bobs. Along with just paper towels.
