Apple A quick (but probably dumb) question
Discussion in 'Software' started by smashie, 16 Apr 2005.
  1. smashie
    smashie Cupid Stunt
    2 Jan 2003
    Hi,
    I know naff all about macs so here goes. I've got a load of files on a usb hard drive which is formatted as NTFS. Can I just plug this in and copy the files to a mac?
  2. StEvEzAsYcHo
    StEvEzAsYcHo What's a Dremel?
    18 Mar 2005
    Im not 100% on this, but it should pick it up as a PC exchange.. I think as long as they are files readable on a mac you should be alright.. If theyre mac-specific, just dont try opening them on your PC or they wont work..
  3. -=ice=-
    -=ice=- What's a Dremel?
    17 Jan 2003
    Dont hold me to this, but i think mac os x 10.2 or later can read ntfs, but not write to it :)
    I always use fat on removeable drives like that (where i can) as just about everything can read them :D
  4. -=ice=-
    17 Jan 2003
    ah ha
    from: http://docs.info.apple.com/article.html?artnum=75320
    It's for a hard drive, but the same should apply :)
  5. smashie
    smashie Cupid Stunt
    2 Jan 2003
    Ok, thanks, I'll reformat it as fat and then try it. All of the files are jpg or office so the mac should read them
