Cooling A quick cooling question...
Discussion in 'Hardware' started by Hazza, 2 Dec 2003.
  1. Hazza
    Hazza What's a Dremel?
    25 Nov 2003
    I know this place is prob not 4 wussy air cooling bt I thought u lot wud know sumat bout it.
    Im looking 2 buy a new heatsink and Im not sure what 2 get.
    Im torn between an Aero 7+ , a ThermalRight and a Zalman flower cooler. The problem is that I dont have mounting holes on my motherboard. Wot wud b the best option?
  2. couzo
    couzo What's a Dremel?
    26 Apr 2002
    wrong forum I think but hey I will answer best I can, just a couple of questions what cpu and do you overclock?
    If you just want silence the zalman is a great cpu cooler I use it when I am changing my water cooling setup and it is very good with the zalman fan you get it works great for overclocking to I used it on my XP1700 at XP2400 and it was fine on the fans silent setting so I would go for that one if it were me
