Modding A Rather Cool Motherboard Mod.
Discussion in 'Modding' started by Guest-23315, 31 Dec 2008.
  1. Guest-23315
    Guest-23315 Guest
    SO this guy decided he wanted a motherboard with a white PCB, so he basically just spray painted his Asus 790i Striker, risking £200 odd in the process...:
  2. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    I'm sorry but that just looks crap
    just my opinion
  3. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    i hate to agree, but i dont like it either :(
    Good to know that i wont have to try though :D
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Red, white & blue. Very patriotic. :D
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    the sight of that just killed a little part of me, makes me very sad!
    It must have been, 'yeah that'll look cool!' at spraying, 'oh, sh*t, oh well might aswell use it now..'
  6. ComputerKing
    8 Sep 2006
    that mobo is CRAP! WTF. IT LOOKS dam ugly. OMG. those guys still got brains or not any more ?
  7. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    I love white PCBs but OMG facepalm! Epic Fail!
  8. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    Yes i want white PCB, but No you have just made it look C***, Pure FAIL!!
  9. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Doesn't really do it for me, I mean it was OK but it seems he got drunk and went wild with a red felt tip...
    Moriquendi
  10. stuartwood89
    20 Aug 2008
    But the black PCB looks so cool, why would you want to have it white? Now it just looks grubby.
  11. bigsharn
    bigsharn Officially demotivated
    9 May 2008
  12. highgeere
    highgeere Not quite there.
    5 Sep 2006
    The white board wouldn't have looked that bad if the other components had matched, but marking all of those bits in red was a poor choice. Still, as a proof of concept(that you can spray a board) it is pretty cool.
  13. stuartwood89
    20 Aug 2008
    Good point, but I would have tested it on a much cheaper board first. And I would have picked a colour other than white.
  14. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Hehe, I've had the same idea for a mod that I might do in the future, though I was thinking about using an airbrush to do the job. Since I feel there is stuff to be learned from this I have a few questions?
    1) Did you use a regular spray paint can?
    2) If so, did you warm it up in hot water prior to painting?
    3) How far away from the MB did you hold the muzzle of the can while painting?
    4) Did you lay down the color in many thin layers or fewer thicker ones?
    5) Did you move the spray can in some kind of systematic pattern (like rows that begins and ends outside the MB)?
    6) Is the paint glossy or mate?
  15. Burnout21
    9 Sep 2005
    I hope all his caps now overheat and blow to teach him a lesson, this is what happens when a rich 14 year old gets hold of a spray can and dosen't think it threw.
    either that or he is an over paid red neck!
  16. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    Or mabye he just made a bad descicion with the colours and isnt actually a stupid 14 year old or a red neck, and before you go slagging people off because they have a expensive component, look in your signiture. IS that a £400 graphics card i see?
  17. Burnout21
    9 Sep 2005
    oh jesus we got one here, let me guess your offend because you too are a 14 year old, if you took the time i mentioned the fact that they were a 'stupid 14 yr old'
    And the matter of the fact that £400 graphics card cost me £244, and i happen to earn a tidy penny as a design director a medical device company.
    I am in no way slagging anyone off for having high end gear, at all. It could be a cheap ass board and i would have said exactly the same.
  18. Xtrafresh
    27 Dec 2007
    well the point is he doesn't treat his components like crap :p
    All ranting aside, i gotta give some credit for the effort, but i think we can all agree that the end result is below expectations.
    I think though that coloring a PCB is something we all thought about at some point. What would be a good way to do it? Let's turn this thread around and make it a brainstormsession on what he should have done.
    I'll start:
    • tape off _all_ the components that are not the PCB. This includes all contacts, all caps, all chips, etc etc. Possibly including all text on there too, though that might need a special solution.
    • use better paint
    • use less paint. This layer is too thick
    • Keep that felttip away from your hardware at all times!
  19. highgeere
    5 Sep 2006
    • don't use white
  20. Burnout21
    9 Sep 2005
    I dont think there is anyway to do it tastefully as the PCB is coloured by adding dye to the resin in the fibre glass.
    The best ones i have seen is full coverings of the board which hides alot of it with aluminium sheet or acrylic.
    either that or the simple mod of taking a UV pen to the edges of the PCB's to give them a green or purple glow under UV light.
    DFI with there UV reactive PCI, PCI-E, memory slots were pretty cool!
