Modding A real guide on how to cut AND drill plexi/acryl is needed!
Discussion in 'Modding' started by Big SturL, 17 Sep 2005.
  1. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Well, the topic of the thread just about says it all. I'm very interested in learning how to cut plexi or acryl properly. There has probably been a flurry of tutorials before, but I couldn't find any.
    I thought about posting this in the "mod guide" section, but was a bit incertain if that was right considering this not being an actual guide.
    So if any of you leethaxxors out there could help me, and post a proper tutorial on this.... it would be nice...:)
  2. wajt
    wajt What's a Dremel?
    4 Sep 2005
  3. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    That thread is good.
    Skill is not necessary, you just need a jigsaw and a steady hand, and cut the pieces you want. For smooth edges, use 600g sandpaper on the edges, then 300g then 100g, or somewhere along these lines. Then use plastic polish and you'll be done.
  4. wajt
    4 Sep 2005
    that could be hard to come by :eek:
  5. MrWillyWonka
    25 Jul 2004
    Don't be nervous or anything, just cut it really!
    And make sure theres no heavily vibrating plastic, make sure the jigsaw base is level with the plastic.
    Trust me, its easy!
  6. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    I don't have particularly steady hands and I do just fine.
  7. mrmunkily
    mrmunkily What's a Dremel?
    16 Sep 2005
    Do you think it would be possible to cut acrylic with a electrically heated nichrome wire? This would be a hella lot easier than real machining.
    similar to this sort of rig?
  8. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    No, the plastic just melts around the hot wire and rejoins behind it.
  9. mrmunkily
    16 Sep 2005
    can the wire be heated enough to vaporize the acrylic much like it can vaporize foam?
  10. wajt
    4 Sep 2005
  11. mrmunkily
    16 Sep 2005
    It seems about right. A blade that "shoves aside" the acrylic after melting it would probably be best, but I don't know of any blade material that is resistant enough to heat up to the right temps.
    Then again, I could attach a propane torch to a scalpel and just slice away with the hot knife...
  12. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    Measure Twice,
    Cut Once.
    End of thread.
  13. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    best way to cut plexi is a table saw be careful though it can break plexi also very easy so take caution wear protection Yes when your cutting and in bed :D flying plexi really hurts i have a dint in my metal shop wall were a piece launched across the room. :wallbash:
  14. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
    scoring tool, low speed dremel, jig saw, band saw, anything that cuts haha
  15. r3Q
    r3Q Minimodder
    31 Jul 2002
    bansaw = my friend. but id prolly use a nice jigsaw with a metal blade and alot of masking taape :)
  16. Firefox90
    Firefox90 What's a Dremel?
    14 Jul 2005
    What has been said above is good. Although, I have been using some really thin plexi for mini projects and cutting by scoring it a few times with a packing knife then firmly planting the piece you are going to use and bending off the spare piece. It's trial and error, but comes out really clean when you get it right.
  17. dom_
    dom_ --->
    4 Jan 2004
    if you want totally clear edges on the plexi either get it laser cut or use a flame on the edges after it has been cut. which is not easily done. but when you get the technique it looks ace.
    as for using a hot blade etc, not going to work. literally the only way to do it like that is laser cutting.
    as for it being a thermoplastic, this has nothing to do with the cutting really. as thermoplastics are basically plastic that can be heated and formed into shape over and over again, thermosets can only be heated into shape once.
  18. Big SturL
    15 Jul 2005
    Well thank all of you for taking such interest in my request! But not only am I interested in cutting the acrylic, but also drilling it. Can someone help me with that?
  19. Big SturL
    15 Jul 2005
    I want to learn how to drill acrylic like they have done here with the HDD mount
  20. Big SturL
    15 Jul 2005
    Would someone please help me?
