A tale of Three Heatsinks
Discussion in 'Article Discussion' started by Tim S, 5 May 2005.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. TMM
    TMM Modder
    12 Jan 2004
    The gigabyte one screams "thermalright SI-97", but bigger and better :p. Has the performance to match too :rock:
  3. Saist
    Saist What's a Dremel?
    4 May 2005
    yeah... the Gigabyte reminds me a lot of some thermaltakes I have...
    anyways, I'm not exactly surprised Coolermaster did such a hot job...
    pun intended.
  4. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Good review, I'm looking for a good and powerful HSF for my new Athlon 64 and I think I'm gonna get the G-Power instead of having the stock cooler. So when is this going to be released?
  5. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    Geez....
    If heatsinks get much larger, you're going to need a plate to attach to the back of the case to keep the things from cracking your motherboard!!
    A 1Kg heatsink? That's crazy!
    Now for another thought. Looking at the Gigabyte cooler, I noticed the heatsink fins didn't make contact with the CPU pad. My thought was, why not make a heatsink in which the fins do go all the way down, *and* you have heat-pipes to transfer some of the temp higher up the fins? Presumably, as you move further away from the heatsink, the temp of the fins gets lower. However, I am not a physicist, heatsink designer, engineer, etc, so I may be way off base on this, and it just plain wouldn't work, or would actually work worse than one way or the other.
  6. Cheese
    Cheese Doc
    6 Oct 2001
    If the heatpipes work well, I.E. they transfer heat from the base to the fins significantly better than a continuous copper/aluminium contact would, then there's no need for the contact. Actually the space is to increase airflow through the fins, it reduces the resistance felt by the fan, helps with airflow and probably reduces turbulance and helps with noise - the cooler works very well, I think Gigabyte have done their homework.
    Cheers,
    Rob.
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Were the tests carried out the the Neo2(NF3) board? From the layout I'm guessing this is the case...
    Good review, coolers are getting insane these days, goes to show though, extra weight doesnt always mean the best cooling....
  8. TMM
    TMM Modder
    12 Jan 2004
    Looks like an MSI K8N Neo (skt754) to me.
  9. Cheese
    Cheese Doc
    6 Oct 2001
    Yep, as it says in the review on page 4 :)
  10. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Directly attaching the fins to the cpu base would actually be very counterproductive. Doing so would cause the heat to dissipate back down the fins and onto the sink again, where you don't want it to sit.
    There is actually a (I believe thermaltake) heatpipe out that has this, and it raises the temperature considerably. Essentially all you have then is an HSF assembly with some funny pipes on it to make it look cool.
Tags: Add Tags
