Build Advice A warning to new builders
Discussion in 'Hardware' started by Orion1, 5 Oct 2012.
  1. Orion1
    Orion1 What's a Dremel?
    5 Oct 2012
    Hi there.
    I am new here but I wanted to share my story.
    So March this year I built my first PC. I did very minimal research and just went and brought everything....
    And I ended up with a broken mess. That barley ever works, Not even the people I got the parts from will touch it.
    So before you build, please look up everything and search for any problems. Or you might end up like me with horrendous build.
    Thanks.
  2. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    What did you build, exactly, and what's wrong with it? :confused:
  3. law99
    law99 Custom User Title
    24 Sep 2009
    Quoi?
    Must have put the Flux Capacitor in the wrong compartment then tried to run it off beer before first trying a banana. Rookie error
  4. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Could this be a case of always R.T.M. and understand what it is saying.
    Sent on my CM10 JB powered i9100 by TapaTalk 2
  5. legoman
    legoman breaker of things
    28 Feb 2010
    Rage over case door that wont come off, followed by dremelling door off then finding its held on by thumbscrews?
  6. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Explain the problem - we might be able to help!
    Unless of course you bought an AMD FX chip, a Z77 motherboard and a Quadro graphics chip.. Then there's not much we can do.
  7. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    In all fairness, if the problem was compatible parts, the rule I always use is RING UP THE SUPPLIER and ask them. This way when something doesn't fit/work, you at least have some come-back.
    Otherwise, you're absolutely right. research pays dividends. Often you're best publishing your intentions somewhere like here, JUST IN CASE there is a better/cheaper way of achieving the same results. Many heads (and eyes) scouring the internet are better than one....
  8. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Worst post ever.
  9. longweight
    7 May 2011
    Lol.
  10. KidMod-Southpaw
    28 Sep 2010
  11. legoman
    28 Feb 2010
    And, its his first post! its all downhill from here
  12. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    It might be a troll.
  13. Yslen
    3 Mar 2010
    I suspect a troll also. No useful advice and no questions, just spreading FUD about self-building.
    Sent from my HTC Wildfire using Tapatalk 2
  14. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    So many things wrong with the post, he can't rma the parts why? Poor research and it "barley" works? It would either work or not work. I call BS.
  15. Pookeyhead
    30 Jan 2004
    As you said. You did minimal research. It is your fault you have a broken mess, because you did minimal research. It is also not advisable to cross the road without doing research into how to do so safely. Operating a hair dryer also requires some fundamental rules to be adhered to. What made you think building a highly complex and sensitive piece of computing equipment exempted you from doing more than minimal research? Surely something complex like this requires some extensive research? The first time I ever built a PC I was reading everything I could find for weeks before so much as think about buying anything.
    1 post only... looks like you're pi$$ed off you built a badly researched mess.. but that's no reason to blast in without saying hello and trying to scare everyone.
    David likes this.
  16. Unicorn
    25 Jul 2006
    It all depends on where you brought the components from really. If you brought them from a decent supplier, they would probably have had no problem answering a few questions on the phone for you. After all, you just brought (probably) several hundred pounds/dollars/euros worth of computer hardware off them.
    Yeah, like it needs to be said again :rolleyes: Worst. Post. Ever.
  17. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Thank you for your post. I shall never again build my own PC, as after hearing your horror story, I now quake with fear every time I see a CPU.
    I will now only ever buy my computers from PCWorld where I know quality is guaranteed.
    Sent from the Starship Enterprise
  18. Teelzebub
    27 Nov 2009
    David likes this.
  19. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Try one of these first and when you've grown up a bit then you can try the real thing :rolleyes:
  20. GeorgeStorm
    16 Dec 2008
    Looks like a bot of some type.
