A7N8X Deluxe V.2 SATA Rator Problem
Discussion in 'Hardware' started by Cyberbob:-), 29 Sep 2004.
  1. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    HI guy's.
    I've got my computer running off a SATA 160gig hard drive on channel 0.
    And now I installed a SATA Rator 74gig ,I can see it in startup and even in device manager but can't see it in my computer folder. I've left the jumpers in default. Can't think what it can be.. :wallbash:
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Have you formatted it?
    Right click on My Computer -> Manage -> Disk Management -> right click on the unformatted space and format it ;) Though with a Raptor you might be wanting to reinstall Windows onto it, it really is worth it for the speed.
  3. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    I formatted through the raid proggy with my Asus A7N8X. While it's booting if you press F4 you can access it that way.
    If I go into My Computer -> Manage -> Disk Management -> Will it see the drive? Since it's not reconised in my computer?
    I've never used that computer management before, looks quite good... :D
  4. Kameleon
    29 Apr 2003
    If it's recognised in Device Manager it'll be seen in Disk Management.
  5. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    I shall try that when I get home, at work at the moment.
    I've had a look under storage and then disk management, Where's the option to format?
    From what I can remember,from my settings at home. Where some drives say online I don't think my Raptor was showing that!!!
  6. Darv
    Darv Bling!!
    12 Aug 2002
    Right click the disk and there is the option to format.
  7. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    It's not showing up in my computer, so I can't do that.
    I'm going to be using computer management..
  8. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    he means in disk managment, where it shows up right click on the box and click create partition or format or suttin like that
  9. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    Oh! I can see it now, Just had a closer look.
    Even thou it's not formatted, shouldn't it still show up in my computer?
  10. Darv
    Darv Bling!!
    12 Aug 2002
    No, if it's not formated it won't show up in My Computer.
  11. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    I went into disc management, And It found it straight away...Thank god for that.
    Formatting it now...
    Thanks guys
