Photos Abandoned Farm, the moon and a chick
Discussion in 'Photography, Art & Design' started by CraZy, 8 Jan 2009.
  1. CraZy
    CraZy Cöstom úser tætel
    1 Feb 2005
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    I would ;)
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    The two HDR ones I like, because you haven't overcooked it.
  4. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
    I like the first shot, though I might have straighten the shot to level the window and floor. Love the colours on the second one. the background off the portrait is annoying specifically the line running through her head and the pronounced shadow, but the rest is great. Love the moon shot.
  5. airchie
    airchie What's a Dremel?
    22 Mar 2005
    ++ :D
    Seriously though....is she single? :D
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    Honestly tho, the second image is brilliant. The colours are awesome.
  7. Vers
    Vers ...
    23 Oct 2007
    For #1, I'm assuming you shot in a doorway? If so, the shot would have been more effective if you could have backed out a bit and shot the room with the doorway in the frame--it feels, and I never thought I'd say this, too tight. #2 works, but the crop is off a bit, unless of course you dig the angle and I would have loved to see that window not blown out. The portrait is good as well, although the shadow distracts a bit from it even though she is easy on the eyes.
  8. CraZy
    1 Feb 2005
    Thanks Guys :) Means a lot to get some input.
    @WhisperWolf Yes the line where the wall meets the ceiling is deffenetly annoying i know, this is whatt happens when you are not thinking about the backround :(
    @Vers The doorway in #1 was so close to the wall that there was no way to back off, I only had the 18-55 with me at the time, Since then I have bought the 10-20mm sigma witch will help me in close spaces like this. And I know they are a litle crooked, the lines in the house (walls, ceiling and even the floor a lil bit) were all over the place, and the angle defenetly exaggerate that, I could have done a litle better job at hiding it :)
    You'r just gona have to travel to Iceland to figure that out haha
  9. Vers
    Vers ...
    23 Oct 2007
    In #2 the window trim is parallel to the wall to its far right, so while the house my not be entirely plumb/square from wall to wall, the room in #2 looks pretty close. Just out of curiosity did you use a tripod for the interiors?
  10. CraZy
    1 Feb 2005
    I used a tripod yes. Almost always a must if im shooting interiors with no flash.
    erm..ok? haha
  11. Vers
    Vers ...
    23 Oct 2007
    OK, good. Focus on squaring your shot next time around and if you don't already, try to use mirror lockup for longer exposures (<1/60), a shutter release cable is also a good idea. Hope that helps :)
  12. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    I like #1 the most, just appeals to me for some reason. there all good shots tho.
  13. CraZy
    1 Feb 2005
    I own a shutter release cable, handy little things, used it with the moonshot.
    And I just read about how mirror lockup works on wiki, never realised it could be used to reduce vibration
    Thanks for the Tips! :)
    *edit* Thanks Tranc3
  14. camvanmvt
    camvanmvt What's a Dremel?
    10 Jan 2009
    I see that all of you need 2 upload pics to share them with others.
    I find a website that very useful for u all www.savehinh.com.
    Check it. n hope that u will like it :) khidotdh88
