Abit Motherboard KT7 - Battery problem
Discussion in 'Hardware' started by y-it-earp, 9 Dec 2002.
  1. y-it-earp
    y-it-earp What's a Dremel?
    13 Mar 2001
    Hi,
    The moulding around the battery on my motherboard has snapped off and thus foked the mobo up from booting i was thinking i could get another from an old board i have and use this glue it on or summat. would this work as i can use this board as a standby
    cheers.
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Try taping it in place with electrical tape, not that I have ever done that but its worth a try.
  3. Adam
    Adam What's a Dremel?
    26 Jan 2002
    You could just unsolder the original battery connection and solder in a replacement.
  4. y-it-earp
    13 Mar 2001
    Ive taken a picture hopefully to make it easier i was thinking id have to solder a wire to each the positive and negative, unsure how though, and then someone fix the battery moulding back into place, any ideads plz?
  5. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    get a nice and fine soldering iron, find yourself some really old pc that you dont need anymore unsolder the batter holder on that one and solder it on your new one, adn hey presto one working mobo...
    if you havent soldered before or lately, try practicing soldering and desoldering on something that doesnt matter first...
  6. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    He may have a problem mounting the original solder because it's high temp solder?
    Alternatively you could just solder wires to the surface of the mobo. be careful not to touch other components though esp chips.
  7. y-it-earp
    13 Mar 2001
    Lol im well an truely bricking it now, what do i do then as the temps will be too high for it?
    oh deary me:eyebrow:
  8. felix the cat
    11 Jan 2002
    i think youre misunderstanding it, you might have problem melting the high temp solder, as you need a fairly good/hot soldering iron to do it....
    just take it slowly and get some practice beforehand....
  9. olv
    olv he's so bright
    23 Sep 2002
    JUST ATTTACK IT LIKE A REAL MAN AND STOP BEING SUCH A WUSS :p
    lol only joking... trick with soldering is to take your time i find, just don't hold the oldering iron down for too long :rock:
  10. y-it-earp
    13 Mar 2001
    well im about to attempt this feat 2moro so hopefully all being well i'll have a motherboard working again, what about the plastic moulding for the bat? how do i get that bk on with solder too?
