Abit NF7-S V2.0 (AMD XP1800)
Discussion in 'Hardware' started by RobbieGSM, 14 Feb 2004.
  1. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Hey Guys.
    I would like to ask all NF7-S V2.0 owners some Q's on the overclocking side of things on this Abit Board.
    I have a AMD XP1800 Tbered B cpu i can get it to 2100Mhz easy
    I would like to know is there any other settings on the mobo at all that i must disable/Enable for a stable board or better other clock this cpu is unlock and i have it running 10.5 mulit by 200Mhz FSB any other way should i try and im already running on 1.875Voltts
    Thank you,
    Rob. :thumb:
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Dont know what the XP1800 can handle, but I've got my XP2800 @ 2.1v, thats with watercooling.
  3. Tim S
    Tim S OG
    8 Nov 2001
    is the chip DLT3C or DUT3C? as it makes a bit of difference as to how far u can push it. DLT3C use 1.5v stock, and DUT3C use 1.6v (or 1.65v) stock. Providing you keep it cool, you can go right up to 1.95v on air with either of them.
    Providing you have good case cooling, you won't need to cool the mosfets at that voltage. :)
