Abit NF7-S V2.0 problem!
Discussion in 'Hardware' started by RobbieGSM, 31 Dec 2003.
  1. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Hi,
    i have the following system
    Abit NF7 S V2.0 bios version 20,
    20GB Satget barruagda 7200RPM (Master)
    10B 5400RPM Drive
    Gefore 4 mx440 64mb (latest drivers)
    AMD Anthlon XP1800 pally
    256mb gerneic ram pc333(2700) ram
    256mb samsung pc133(2100) ram
    Sony CD-RW CRX 145e
    Samsung SD 608 DVD-ROM
    375w Advice PSU
    Windows XP PRO
    My problem,
    i was building this systemLast night
    i put every thing in and hit the power botton
    hmm no display
    and i hear beeep...........beeep.........beeep
    it dose not stop each beep is about 3secs apart,
    so i took one stick of ram out
    same thing happend,
    so i took both sticks out and put the 2700 in slot one (the one the is away from the other two,
    every thing boots up just fine,
    hmm OK,
    then i put pc2100 ram in the slot 2
    same thing,
    so then i take both of them out and put 2100 in slot one,
    works fine,
    please tell me whats happing and how to fix this,
    P.s love the new board overfloe :rock:
  2. Trickle
    Trickle What's a Dremel?
    14 Dec 2003
    Set the board up for non spd detection, cas 2.5 /3/3/6 133 fsb with non agressive cpu interface and put both sticks back in and see if it likes it better.
    Edit: leave cpu interface on agressive to start with.
  3. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Okay thanks i will try that @ home
  4. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    that or since slot 2 dont work it may be bad, i had a board like that
  5. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    most likley a ram/dimm slot problem by the sounds of things.
  6. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    im not even going to bother putting that 2100 in there again since i have taken it out i can now get from
    133FSB x 11.5 = 11.53Ghz
    TO
    148 FSB x 11.5 = 1.70Ghz
    as to when i had both in there i could only get max 142FSB and even then it was unstable :) :clap:
  7. BenJa
    BenJa What's a Dremel?
    26 Jun 2003
    Wow 11.53 Ghz :lol:
    I'd leave it as it was ;)
