I have the IC7-Max3 mobo, with the Otes cooling. I wanted to replce the green LEDs for bloo ones. has anyone done this, and if i did it, all I have to do is desolder the old ones, and solder in the new ones?
I haven't even plugged my otes mobo in yet (can't afford a cpu!) so i can't be certain, but i'd say that you should be ok just to replace the led. Just be sure to use a heat sink when you do it.
