Build Advice About to order my new SB build
Discussion in 'Hardware' started by r3loaded, 12 Feb 2011.
  1. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Right guys, I'm gonna order the parts for my rig very soon - by a stroke of luck, Scan has put almost everything I need on the today-only page! :clap:
    Just want it checked over before I pull the trigger:
    • Silverstone FT03
    • Coolermaster Silent Pro Gold 600W
    • Core i5 2500K
    • Coolermaster Hyper 212 Plus
    • Asus P8P67-M
    • Corsair Vengeance 8GB 1600Mhz
    • KFA2 GTX 560 Ti EX OC
    • Samsung F3 1TB
    I'm also looking for a combined TV/monitor to go with this, and am currently looking at the Samsung XL2270HD. Is that fine, or is there any other model I should look at for around £200?
  2. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    That looks totally fine. No issues that I can see anywhere ^^.
  3. murraynt
    murraynt Modder
    6 Jun 2009
    looks sweet. Might be worth getting the PRO version if you ever want SLI. Can't comment about the T.V though.
    Would the Antec true power 650 not be a better buy at that price?
  4. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    I don't think I'll ever want to SLI - by the time I want to upgrade, we'll be on the next-generation of cards, or even the next-next-generation! :thumb:
    I was going to go for the Antec, but the Coolermaster is only £6 more in the sale, 80 Plus Gold certified and I quite like the gold on black design. :)
  5. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Just be aware of the current Sandy bridge issues - be willing to replace your motherboard in a few months or use just SATA channels 0 / 1 or use an add-in SATA card.
  6. Synalar
    Synalar What's a Dremel?
    7 Feb 2011
    Seasonic X or Corsair AX are few steps above your PSU; not that there is any big difference. :)
    LG W2353V-PF is a nice and truly affordable monitor.
    LG W2442PA
    Samsung 2494HM
  7. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    with the amount of asus 1155 issues, i would give hard consideration to switching to a gigabyte board....
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    @oasked: I already know about the SB chipset issue, and will probably claim my replacement in April/May.
    @Synalar: I'm actually looking for a good TV that can also act as a decent monitor.
    @Sludge: Gigabyte don't have any microATX boards.
    EDIT: Ordered it, decided to get the Pro after all. And I got the Samsung XL2270HD from Electrical 123 for just £190.99 + free delivery :)
